Thread: Lock pulley top remove 24mm bolt?
Results 1 to 20 of 22
  1. #1 Lock pulley top remove 24mm bolt?
    Jan 2015
    United States
    Guys I'm stuck trying to get bolt off 2007 gp harmonic balancer..Included I have pics of where I am.My air compressor died and I am heading in to replace Timing cover gasket.Thanks
    Randy
    http://s1262.photobucket.com/user/Randy_Pappas/library/
  2. #2 Re: Lock pulley top remove 24mm bolt?
    You can use like a large pair of vise grips to hold/wedge the flex plate in place to stop the crank from moving, then use the breaker bar from up top and use like a piece of pipe or jack handle to extend it to give you extra leverage to remove the bolt.
  3. #3 Re: Lock pulley top remove 24mm bolt?
    Jan 2015
    United States
    You lost me at flex plate.LOL Let me find a pic.Thanks for helping this old un-educated guy out.
  4. #4 Re: Lock pulley top remove 24mm bolt?
    or use the starter motor, set the breaker bar on a jack stand or a jack and crank the engine over.
  5. #5 Re: Lock pulley top remove 24mm bolt?
  6. #6 Re: Lock pulley top remove 24mm bolt?
    Jan 2015
    United States
    Is there a lip I can hook the vice grips onto I can't seem to find it.
  7. #7 Re: Lock pulley top remove 24mm bolt?
    Jan 2015
    United States
    The engine is tore down.I would have to go back and reinstall alt-pp-idler water pump bolts and belt to do that?
  8. #8 Re: Lock pulley top remove 24mm bolt?
    The crank always spins regardless, it doesn't need any belts to do the starter trick.
    The flex plate is what bolts the torque converter to the engines. There is a little black cover between the motor and transmission on the bottom that will give you access to the flex plate.
    Just pull the fuel pump fuse/relay if you do the starter bump trick so the engine doesn't run.
  9. #9 Re: Lock pulley top remove 24mm bolt?
    using the starter is going to be the easy way to go about this. no need for all that stuff to be hooked up. even if it did start just turn it off fast, nothings gonna get messed up cause it ran a few seconds.
  10. #10 Re: Lock pulley top remove 24mm bolt?
    Jan 2015
    United States
    Thank you Im giving it a shot
  11. #11 Re: Lock pulley top remove 24mm bolt?
    Jan 2015
    United States
    Bingo worked like a charm.Called the kids told them I loved them before turning the key.On to the next step.
    Thanks Guys
  12. #12 Re: Lock pulley top remove 24mm bolt?
    you got the right size bolts for the puller to the balancer i hope. the right size dont come with a puller kit.
  13. #13 Re: Lock pulley top remove 24mm bolt?
    Jan 2015
    United States
    Just now realized that. bought oemtools27187 because I got it overnight.What size am I looking for?Isn't the pressure point suppose to go thru the hole to the threaded hole.When setting the puller up
    Update
    Got it pulled, More in morning.2 degrees in Iowa and I need some heat.
    Thanks
  14. #14 Re: Lock pulley top remove 24mm bolt?
    http://www.grandprixforums.net/threa...a-crank-sensor bolts are listed here. as well as the crank sensor tq.
    the bolts thread into the balancer you'll need washer to keep the heads from pulling through.
    and you want a puller like this. if it has that foot on the end pop it off, you want the threaded rod to go in past the threads in the crank. id put some anti seize on the threaded rod too.
  15. #15 Re: Lock pulley top remove 24mm bolt?
    Jan 2015
    United States
    Thanks, Five and Scotty.I am on the cleaning stage.I left the water pump on the cover when I pulled it since it was installed last week.Should I removed and reseal with the cover.Any tips on reassembly?
  16. #16 Re: Lock pulley top remove 24mm bolt?
    when your ready to install the new gasket, smear rtv 2 inches up the block, and on the gasket 2 inches up when its put on and, around the oil pan gasket, sealing those two corners up nice.
    some of the threaded holes go through the block into the coolant. best to use some thread sealant on all them bolts, the 4 long w/p bolts for sure need this and a few others. or the threads can leak later.
  17. #17 Re: Lock pulley top remove 24mm bolt?
    Jan 2015
    United States
    Im on it Scotty.I was going to ask about the oil pan since i did not pull the whole thing.I will update in a couple hours.
    Thanks
    Randy
  18. #18 Re: Lock pulley top remove 24mm bolt?
    Jan 2015
    United States
    I added 3 pics of the suspect corner of the timing cover is that a crack on the inside?It dont show on the outside to me.
  19. #19 Re: Lock pulley top remove 24mm bolt?
    this lic looks like a casting mark.
  20. #20 Re: Lock pulley top remove 24mm bolt?
    Jan 2015
    United States
    Thanks Scotty,Im being cautious as now is the time to question everything,Back to the project,I will update soon.
    thanks
    Randy
  1. How to remove a really stubborn bolt?
    By GrandPrick97 in forum General Tech Discussion
    Last Post: 12-29-2014, 12:22 PM
  2. How to remove this weird screw/bolt
    Last Post: 12-27-2014, 08:05 PM
  3. New prix comes with problems..key lock..Oil pan bolt...
    By chicagochuck in forum General Tech Discussion
    Last Post: 04-04-2013, 06:41 PM
  4. Best way to remove broken bolt
    By tms8582 in forum Brakes/Suspension/Chassis
    Last Post: 12-14-2011, 02:48 PM
  5. HELP! Can't remove crank pulley bolt!!!
    By Billy Low in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:06 PM
