Thread: 02 gp gr8 3.8 leaking coolant around under throttle body side?
Results 1 to 2 of 2
  1. #1 02 gp gr8 3.8 leaking coolant around under throttle body side?
    Sep 2015
    Lansing, Michigan
    I have a leak and it's around where the throttle body is. It runs around the uim gasket on that side but I can't seem to figure of its tb gasket or uim gasket. Last time I saw the leak, I found a loose stud on the tb to uim on the bottom so I tightened it but stripped the stud so I just switched the studs around and put the bad one on top.
    So I plan on going to jy and pulling some tb to uim studs and replacing the tb gasket.
    I just replaced the uim and lim gaskets a year ago and I did the uim with all new plenum, and dorman upgraded egr pipe for uim. What could it possible be? Coolant is only coming from the tb side. I have no coolant in the oil.
    Like I said the coolant leak is right around under the tb and I can't tell if it's uim, the uim gasket, or tb gasket. I dread pulling uim in this cold michigan weather
  2. #2 Re: 02 gp gr8 3.8 leaking coolant around under throttle body side?
    Nov 2014
    FORT WORTH TEXAS
    It could be the block off plate gasket leaking on the end of the intake a pressure tester from auto zone that's basic a free rental could help. Test it stone cold first for any leaks when things expand some times they stop leaking. As a loose hose clamp can.
  1. Coolant leak from Throttle body
    By jakegsxr11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-05-2022, 07:48 AM
  2. coolant leaking? passenger side block wet
    By hitnf in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-15-2017, 09:53 AM
  3. 02 gp leaking coolant on drivers side?
    By tom5170 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2016, 06:53 PM
  4. Leaking Coolant from Front Driver side
    By mstrozier in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-28-2011, 11:15 AM
  5. coolant is still leaking around LIM at passenger side
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2010, 10:11 PM
