Thread: Junk Yard Supercharged Engine?
Results 1 to 10 of 10
  1. #1 Junk Yard Supercharged Engine?
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    Hey i found a cheap supercharged engine at the junkyard will it be a good idea to put it in my GT since my engine went out on me
    Sent from my SM-N920T using Tapatalk
  2. #2 Re: Junk Yard Supercharged Engine?
    Not to be harsh but if you have to ask I can only assume you don't know exactly what you are getting into.
    Yes the motor would fit but how will you do everything else?
    You'd need a tune for sure, depending on year and if you have the vacuum 4T60e I wouldn't want to do the swap.
  3. #3 Re: Junk Yard Supercharged Engine?
    Sep 2014
    New Orleans
    Oh ok my timing chain went out and it dont crank anymore and my mechanic said it would be easier and faster just to get another engine
  4. #4 Re: Junk Yard Supercharged Engine?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Your mechanic sounds like a moron. Not cranking has nothing to do with a bad timing chain, and it wouldn't be solved with a new engine.
    GPONA #1 Cyber Bully
  5. #5 Re: Junk Yard Supercharged Engine?
    Sep 2014
    New Orleans
    What could cause the belt and none of the pulleys to spin then?
  6. #6 Re: Junk Yard Supercharged Engine?
    SE Level Member therealtoddster's Avatar
    Oct 2016
    A bad starter would be my first thought.
    Sent from my SM-G920R4 using Tapatalk
  7. #7 Re: Junk Yard Supercharged Engine?
    or a seized up block. put a socket on the crank bolt and try to turn the engine over.
  8. #8 Re: Junk Yard Supercharged Engine?
    I've seen a few bad chains, typically it was an aftermarket double roller before they were figured out as being Aussie crank chains and not US. I've seen a couple tensioners go bad and hose things up.. but it's not common at all.
  9. #9 Re: Junk Yard Supercharged Engine?
    Could have hydro-locked too, pull a spark plug or two and you'd really know that answer.
  10. #10 Re: Junk Yard Supercharged Engine?
    Quincy, Mass
    97 gtp Pcm for sale, its in Canada so shipping will be a little more.
    97' GTP PCM + Other Parts
    https://r.tapatalk.com/shareLink?url...8&share_type=t
    No more GP 04 Impala SS Indy:
  1. 97 Grand Prix 3.8 Supercharged engine at local junk yard. Worth saving?
    By sgtmac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2015, 08:38 PM
  2. Junk yard find!
    By mkyota1 in forum General Grand Prix Discussion
    Last Post: 05-13-2012, 11:57 AM
  3. junk yard find
    By Scottydoggs in forum Off Topic Discussion
    Last Post: 03-28-2012, 07:17 PM
  4. 97 gtp in the junk yard
    By ibhuff in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2011, 06:51 PM
  5. I love the junk yard
    By Mad Monkey in forum Audio, Security & Visual Electronics
    Last Post: 07-22-2009, 01:01 PM
