Hey i found a cheap supercharged engine at the junkyard will it be a good idea to put it in my GT since my engine went out on me
Sent from my SM-N920T using Tapatalk
Not to be harsh but if you have to ask I can only assume you don't know exactly what you are getting into.
Yes the motor would fit but how will you do everything else?
You'd need a tune for sure, depending on year and if you have the vacuum 4T60e I wouldn't want to do the swap.
Oh ok my timing chain went out and it dont crank anymore and my mechanic said it would be easier and faster just to get another engine
Your mechanic sounds like a moron. Not cranking has nothing to do with a bad timing chain, and it wouldn't be solved with a new engine.
I've seen a few bad chains, typically it was an aftermarket double roller before they were figured out as being Aussie crank chains and not US. I've seen a couple tensioners go bad and hose things up.. but it's not common at all.
97 gtp Pcm for sale, its in Canada so shipping will be a little more.
97' GTP PCM + Other Parts
https://r.tapatalk.com/shareLink?url...8&share_type=t
