Thread: Throttle position sensor low voltage cody
Results 1 to 3 of 3
  1. #1 Throttle position sensor low voltage cody
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    Hey i just got my car scan and a code for the tps came up and said low circuit. I just purchased a new tps yesterday. How can i fux it because my acceleration and idle was bad on ly way home
    Sent from my SM-N920T using Tapatalk
  2. #2 Re: Throttle position sensor low voltage cody
    Did the new TPS sensor fix the issue or do you have yet to install the new sensor?
    If the problem is still there, you have a power/ground issue to the sensor. You need to check the wiring and any related fuses that deal with the TPS sensor.
  3. #3 Re: Throttle position sensor low voltage cody
    Sep 2014
    New Orleans
    The problem is fixed i took it to a shop and they did a reset on the computer its acelerating and idling good now
  1. Throttle position sensor
    By GTPWINDYCITYBOI85 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2013, 04:42 PM
  2. throttle position voltage
    By reem98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2011, 10:15 AM
  3. Throttle Position Sensor
    By apierce1289 in forum General Tech Discussion
    Last Post: 06-07-2011, 09:00 PM
  4. throttle position sensor
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2010, 11:16 AM
  5. THrottle position sensor
    By xsvtank in forum General Tech Discussion
    Last Post: 11-27-2010, 07:17 PM
