Thread: Dreaded p0455 code
Results 1 to 10 of 10
  1. #1 Dreaded p0455 code
    SE Level Member 08 gp lvr's Avatar
    Nov 2011
    north bay, ontario
    Hey gang. I have a p0455 code that's been lingering awhile. I removed the purge valve and tested it with a battery and it emmitted a loud audible clicking noise, I suspect that it's a good one?? I checked the vent valve and the noise was pretty faint and I didn't see the spring depress. It's running awful, it misses and when I'm at a constant speed itl surge, the rpms will jump up and down consistently a good two times a second. That's my only code. I did check over all the lines from the tank and seem pretty good, no rust. I was to blow thru the hose on the vent valve freely.
    One thing tho, is that I can move the vacum line on the surge valve a lil. In and out I mean. I'm lost here guys, any help would be great.
    08 gp na
  2. #2 Re: Dreaded p0455 code
    Nov 2011
    north bay, ontario
    Could plugs cause this?? My lim was leaking for awhile before I changed it, but it overheated my plugs and made them white like the Haynes manual shows. Wondering if that could be the culprit. Probably doesn't help, and I replaced the gas cap as well.
  3. #3 Re: Dreaded p0455 code
    Plugs turn white from burning coolant or running extremely lean, not from over heating an engine.
    My guess is one of the big tubes leading to the intake for the EVAP is broken or cracked.
  4. #4 Re: Dreaded p0455 code
    Nov 2011
    north bay, ontario
    The bigger line your speaking of, is that one going to the purge valve?
  5. #5 Re: Dreaded p0455 code
    Nov 2011
    north bay, ontario
    What do you think about removing the metal lines from the filler neck and replacing them with rubber lines? Just want rule everything out
  6. #6 Re: Dreaded p0455 code
    you got a large evap leak. it could be the gas filler neck tubes. the little one is a vent yo yhe gas tank and likes to rust out.
    smoke test would find this. even if its else where. that evap line under the hood, runs all the way to gas tank area. canister tank lines could all be leaking too.
  7. #7 Re: Dreaded p0455 code
    Feb 2016
    Washington, DC
    Hi all. I got the P0455 and the "Check gas cap" warning on my '07 GP 3.8L. Changed my gas cap and mechanic did a smoke test and found no leak. If no leak, how else could I be getting that message? Thanks!
  8. #8 Re: Dreaded p0455 code
    SE Level Member therealtoddster's Avatar
    Oct 2016
    EVAP canister solenoid. Permanent fix.
    https://youtu.be/EVZA4V2oi2I
    Vid how to ^^^
    Sent from my SM-G930R4 using Tapatalk
  9. #9 Re: Dreaded p0455 code
    Feb 2016
    Washington, DC
    Thanks! I ended up solving the problem a different way: selling the car to a GM mechanic.
  10. #10 Re: Dreaded p0455 code
    Nov 2011
    NY
    Sold the car to fix an evap leak? O.o
  1. The dreaded P420 code in CA
    By ericwarner2001 in forum Introductions/Noob Questions
    Last Post: 09-18-2018, 11:18 PM
  2. P0455 code with values
    By 08 gp lvr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2016, 08:47 PM
  3. OEM #- P0455 help !! 05 GXP
    By Timmaayy2121 in forum Introductions/Noob Questions
    Last Post: 01-02-2016, 12:14 PM
  4. Trouble code P0455
    By powerranger262 in forum General Tech Discussion
    Last Post: 09-23-2014, 03:09 PM
  5. Check Engine code P0499 and P0455 P0455p
    By itzharrison in forum General Grand Prix Discussion
    Last Post: 09-08-2014, 10:49 AM
