Thread: Lifter & lifter guide change HELP.
Results 1 to 2 of 2
  1. #1 Lifter & lifter guide change HELP.
    SE Level Member 97Darktealgp's Avatar
    Jun 2016
    Cincinnati
    Ok I had a tick when I start the car and goes away until warm. I used a little seafoam a couple months ago to quiet it down which it did. But yesterday while driving I feel a slight hesitation, pull over and hear the same tick noise but louder. At first thought Im thinking a thrown rod bearing. Still uncertain but I ordered new ls7 lifters, and went to take out the old ones I noticed the plastic guide was slightly cracked and when removed two or more lifter were off position by half a centimeter im guessing. Will this cause a lifter tick or slap? The lifters also have a little grooves on them. Just wondering if this will indeed cause that to make a contant lifter tick that sounds similar to a knock, if so how damaged is the cam??? Drove it to the nearest driveway soon a I heard it.
  2. #2 Re: Lifter & lifter guide change HELP.
    Use a flash light to see if the cam is damaged, turn the motor with a wrench to see all the lobes.
    Grooves in the lifter and allowing them to move around could cause extra noise for sure.
  1. How can you tell if a lifter is bad
    By Eric Whitter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2013, 06:45 PM
  2. lifter guide plate
    By Utter99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2012, 08:27 PM
  3. ticking lifter
    By ionroller in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2010, 12:21 PM
  4. Bad Lifter?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 10:03 PM
  5. Lifter Tick
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2008, 06:43 PM
