Thread: 2008 Grand Prix Base Possible injector issue Code P0305
Results 1 to 6 of 6
  1. #1 2008 Grand Prix Base Possible injector issue Code P0305
    Apr 2016
    South Florida
    2008 Grand Prix, Base 135,000 miles, auto trans. I replaced spark plugs about 6 months ago. Engine ran just fine. No codes. I recently decided to clean electronic Throttle Body as I noticed it was quite dirty/gummy black stuff. Removed Throttle body and cleaned with throttle body cleaner. At that time I noticed additional dirty/gummy black stuff in the plenum, which I also cleaned inside as much as possible. Also removed EGR and sprayed with TB Cleaner as well. While I was at it, I used Mass Air Flow Sensor Cleaner for the MAF. Now the engine runs a little bit rough and engine light blinks when I accelerate. Additionally, car now throws Code P0305. Is it possible that I might have clogged a fuel injector during the cleaning of the Plenum? If so, is there a DIY method to clean the injectors? Any ideas are appreciated. Thank you
  2. #2 Re: 2008 Grand Prix Base Possible injector issue Code P0305
    I find it easier to just go back over what you have done.
    Cylinder 5 is on the front, closest to the air box. I would just pull the plug wire and spark plug and inspect them. Then swap the plug with cylinder 3 and see if the misfire moves. If not, swap the plug wire, then swap the coil packs around and see what it does. Once you know it's not a spark issue, then look into swapping the injectors around.
  3. #3 Re: 2008 Grand Prix Base Possible injector issue Code P0305
    Apr 2016
    South Florida
    I'm not sure I understand what Cylinder 5 spark plug has to do with this problem. I haven't touched spark plugs in 6 months. The problem started yesterday after cleaning Throttle Body, EGR and Plenum. Can you explain further? Thanks.
  4. #4 Re: 2008 Grand Prix Base Possible injector issue Code P0305
    P0305 is a cylinder 5 misfire code.
    Misfires are either ignition related or fuel related. So something is wrong on the spark plug/plug wire/coil pack or it's an injector problem.
    Just because you've done the plugs a 6 months ago, doesn't mean they aren't the problem. Start with one thing and work to the next to solve the problem.
  5. #5 Re: 2008 Grand Prix Base Possible injector issue Code P0305
    Apr 2016
    South Florida
    [QUOTE=Fivefingerdeathpunch;1424993]P0305 is a cylinder 5 misfire code.
    Just because you've done the plugs a 6 months ago, doesn't mean they aren't the problem. Start with one thing and work to the next to solve the problem.[/
    OK, Engine Light is off.
    I re-cleaned EGR and removed Heat Shield from #5 plug. Car ran great. Of course I couldn't know which procedure fixed the problem. Sometimes it's hard at my age to remember, when you're up to your arse in alligators, it's difficult to remember that your job was to clean the swamp. At any rate, I then reinstalled the Heat Shield for plug 5 and sure enough the performance decreased and Code P0305 reappeared. Erased code P0305, removed said shield, no more code or performance issues. Anyway I want to thank Fivefingerdeathpunch for his/her invaluable assistance and others who took their time to read my issue.
  6. #6 Re: 2008 Grand Prix Base Possible injector issue Code P0305
    Atleast it's fixed, I always toss those things in the trash anyway haha.
  1. What trans can go into a 2008 grand prix base model?
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-21-2014, 08:52 PM
  2. 2008 Grand Prix - Base
    By 67GTONUT in forum For Sale - Vehicles
    Last Post: 08-24-2013, 11:21 AM
  3. 2008 grand prix (base) running hot.
    By unzip2000 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-02-2013, 11:42 AM
  4. 2008 Grand Prix Base Wheels
    By ajaxjblue in forum Tires & Wheels
    Last Post: 10-05-2009, 12:33 PM
  5. 2008 Pontiac Grand Prix Base Edition
    By MarkedAchilles in forum Audio, Security & Visual Electronics
    Last Post: 01-28-2009, 11:49 AM
