Thread: Rough idle
Results 1 to 3 of 3
  1. #1 Rough idle
    Sep 2015
    Michigan
    This car has like a million miles on it but still a great little get around town car for the kid. Just started getting a P0300 code (Mult. misfire). Did a diagnostic long term fuel trim is -12 but when going down the freeway and take my foot off the gas it goes to like -27. The short term fuel trim is fine running from -3 to +3 on both banks. I don't think it is a fuel problem going to put a gauge on it later and check pressure at fuel rail. Question should my Long Term Fuel Trim adjust that quickly? Also going to start checking plugs and coil packs. Did a vac check (break cleaner) and didn't notice any change anywhere and cant hear a hiss anywhere. Just wondering if I'm on the right track. I know I should check compression but don't have a gauge for that yet. Here I come Harbor Freight. Thanks for any thoughts.
  2. #2 Re: Rough idle
    St. Louis
    When was the last time plugs and wires were changed? If recent, you didn't install platinum plugs did you? These cars eat plats. Go with stock iridiums or copper. Check to be sure the plug wires are in the correct order as these cars will run quite well with a few wires crossed believe it or not.
  3. #3 Re: Rough idle
    Sep 2015
    Michigan
    When I tried to pull a plug wire to check plug it fell apart. Replaced plugs and wires running great.
  1. P0171 and P0300 Codes, Mildly Rough Idle, Rough on starts, Slightly Elevated Idle
    By nskyline34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2021, 07:49 PM
  2. low rough idle
    By lewis1952 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-07-2013, 03:51 AM
  3. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  4. rough idle
    By stanggreg90 in forum General Tech Discussion
    Last Post: 05-22-2010, 11:37 PM
  5. GTP Rough Idle
    By jaredhagen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2010, 01:32 PM
