Is it normal to have 19° of timing advance on a l36?
Sent from my LG-D851 using Tapatalk
It's a huge timing table. Can you be more specific ?
Not really I'm a newbie at modding motors but I just got the torque pro app and under the timing advance section it shows 19° of timing advance and that seemed like a lot.
Thanks scotty! Also now that Ive been messing with the torque pro app it has a lot of cool stuff like vacuum pressure and MAF reading the only problem is I don't know what there supposed to be reading so is there a write up or something that shows normal reading for these sensors so I can tell if I'm on point?
I get about the same. At 70mph 1800ish RPM I'm looking at 30+ degrees advanced timing.
Well see I'm trying to figure out if I have a vac leak or something else cause I get 16mpg city and I would think I could at least get 18 I don't drive with that lead of a foot lol
As far as torque goes getting real time readings depends a lot on how good of a Bluetooth OBD dongle you have. If you got a cheap chinese made one invest in a better one with a faster refresh rate.
