Thread: dumb question
Results 1 to 18 of 18
  1. #1 dumb question
    Sep 2014
    colo springs, co
    I got a belt tensioner from auto zone and it only needs one coolant elbow any one else here about this... the part works and fits also when re connecting the heater lines the bottom hose goes on the top correct because that so the only way it would fit thanks
  2. #2 Re: dumb question
    your lower elbow is cast to the alt bracket. you wiggle the old alt bracket off carefully so you dont crack the timing cover, then clean the hole. then if the new alt bracket dont come with a new O ring take the one that fits from the unused elbow from the new elbows you bought and roll it on the cast elbow on the alt bracket.
    oil the o rings and slide them in the holes.
  3. #3 Re: dumb question
    Sep 2014
    colo springs, co
    I replaced the belt tensioner and it fits I'm not leaking ( that I know of) so I'm more then certain I did it right... the hoses that connect to the tensioner that run from the fire wall bottom connected to the top is that correct or am I upside down?
  4. #4 Re: dumb question
    The hose that comes out the top on firewall goes to the top of the bracket iirc.
  5. #5 Re: dumb question
    Sep 2014
    colo springs, co
    For some reason the brackets with the 10 mm bolts wouldn't fit that way so I'm wondering if i bent the bracket to much? And will ut hurt the car if i drive it like that?
  6. #6 Re: dumb question
    Why did you remove the little brackets? Put them back where ever they were and just pull hoses off.
  7. #7 Re: dumb question
    Sep 2014
    colo springs, co
    They came off with the hoses needed them on the new part
  8. #8 Re: dumb question
    Something tells me you got the wrong part. Can you post pics of the old and the new one?
  9. #9 Re: dumb question
    Quote Originally Posted by Slick2500 View Post
    i bet the new alt bracket failed to have the ends. so you take your old ones off and re use them.
    you can try to bend the metal tab the bolt goes through if it wont line up right for some reason.
  10. #10 Re: dumb question
    Sep 2014
    colo springs, co
    Your right Scott so main question is will it jack up my engine if they are on backwards?
  11. #11 Re: dumb question
    Sep 2014
    colo springs, co
    And one tab is shorter then the other it seems so the way I have it is the way it fits
  12. #12 Re: dumb question
    whats backwards, the way the hoses are to the heater core? dont think that would matter.
  13. #13 Re: dumb question
    Sep 2014
    colo springs, co
    Well the ones that connect to the bracket if they are backwards?
  14. #14 Re: dumb question
    post a pic, im lost
  15. #15 Re: dumb question
    Sep 2014
    colo springs, co
    There are two hoses that go from the fire wall to the belt tensioner assembly... if they are backwards will it effect my engine I started it when I put on the belt but only for 5 min. Can't post a pic until tomorrow
  16. #16 Re: dumb question
    i dont see how the hoses being swapped can hurt any thing.
  17. #17 Re: dumb question
    Sep 2014
    colo springs, co
    Ok thanks
  18. #18 Re: dumb question
    Sep 2014
    colo springs, co
    Just in case any body was wondering if you switch the hoses coolant will blow out the hose and on the the belt... live and learn
  1. Probably a dumb question..
    By Cmgoffe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2014, 11:16 AM
  2. Dumb question......
    By comatoast in forum General Tech Discussion
    Last Post: 12-07-2012, 09:15 AM
  3. Might be a dumb question, but...
    By SteveCZ28 in forum General Tech Discussion
    Last Post: 02-19-2011, 11:06 AM
  4. Dumb question of the day
    By johnb62 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-06-2010, 12:13 AM
  5. dumb oil question
    By J06GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2010, 12:27 AM
