Thread: just got done with timing belt on my 93 grand prix DONT FORGET THE ACU TO TENSIONER
Results 1 to 2 of 2
  1. #1 just got done with timing belt on my 93 grand prix DONT FORGET THE ACU TO TENSIONER
    Jan 2009
    nc
    Just got done with my 3.4 timing belt. There is an actuator that pushes on the tensioner pully, you wont hear or read about this part untill you get inside and see it. It it not mentioned or availeble in any of the kits, it is a dealership part only 117.00. If you dont replace this with the kit it can break the new belt and cause a do over.
  2. #2 Re: just got done with timing belt on my 93 grand prix DONT FORGET THE ACU TO TENSIO
    Apr 2012
    Denver
    Shouldn't need to replace, just make sure to properly refill with preferably full synthetic 5 wt. oil. Also make sure to tighten the bolts for the front smaller retaining plate only to the specified torque or you may break the bracket behind the actuator. To get the details for this procedure, be sure to search for the service bulletin update to the timing belt procedure which explains it in mediocre detail. Also, don't put the actuator in until the timing belt is secure around every gear and the tensioner pulley, and make sure the push rod is fully retracted or you'll never get it seated properly in the little pivot cup. Its a tight fit you may need to put a wrench on the tensioner pulley to push it foreword enough to get the actuator seated properly. Then you can pull the pin out.
  1. Dont forget to vote!
    By SyntheticShield in forum The Rant Forum
    Last Post: 10-25-2013, 01:06 PM
  2. Size wrench needed to adjust belt tensioner for accessory belt install?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2011, 09:29 PM
  3. 1995 Grand Prix GTP ! Timing belt question
    By Rockhound in forum General Tech Discussion
    Last Post: 05-15-2011, 08:47 PM
  4. 1994 pontiac grand prix se timing belt questions
    By 1994grandprixse in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-02-2010, 10:04 PM
