Thread: 180 vs 195 t'stat on 3.4
Results 1 to 6 of 6
  1. #1 180 vs 195 t'stat on 3.4
    SE Level Member Teardrop's Avatar
    Indiana
    I believe mine has the 180 right now as in normal driving, the temp gauge doesn't go above 1/4 way, unless it is a lot of stop and go.
    that is fine in this heat but my concern is when it gets cold this winter, am I going to need to change to a 195 so that the heater will actually work?
    I know the 3.8 series II has the same thing going, I used to have to swap stats between cold and hot seasons...
    Now if it ran a 195 in hot weather, how would that effect performance and all?
    What is the best route here? I am tepted to just swap back and forth or is that a bad idea?
    94 Grand Prix GTP, 3.4
  2. #2 Re: 180 vs 195 t'stat on 3.4
    Delaware, OH
    Stick with the 180. Didn't notice any difference during the winter. Heater would still make you sweat.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  3. #3 Re: 180 vs 195 t'stat on 3.4
    Indiana
    I shall do that.
    I know on my 3800 series II in the winter the heat just didn't work for crap, I won't be able to test this until it gets real cold out but for the time being I will assume the heat will be good.
  4. #4 Re: 180 vs 195 t'stat on 3.4
    in all honesty everyones obsession with running a colder thermostat is silly. running the motor 10-15* colder will not help with knock prevention nor will it do anything for performance.
    run the stock thermostat and get better gas mileage.
  5. #5 Re: 180 vs 195 t'stat on 3.4
    Indiana
    When I got it, it had the 180. Well I am real sure it does, haven't actually looked at it but based on the temp gauge, it doesn't get very high
    One day I will dig into it and put in the 195.
  6. #6 Re: 180 vs 195 t'stat on 3.4
    Nov 2008
    conn
    the 3100 in mine is 195 stat,which i was told this engine is a hot running engine anyway,my 3.8 in my gt is a drilled 180 and in the summer the engine dosent go over 175,reason i did this is because of the blower i had installed along with other mods
  1. 180 stat
    Last Post: 07-12-2009, 08:41 AM
  2. 180 T-Stat
    By xerxescct in forum General Tech Discussion
    Last Post: 07-08-2009, 11:19 AM
  3. should i get a 180 or 160 t stat?
    By 98gtp1000 in forum General Tech Discussion
    Last Post: 02-21-2009, 10:15 PM
  4. 180 T-Stat
    By wykabryan in forum General Tech Discussion
    Last Post: 11-17-2008, 03:27 PM
  5. t-stat ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 04-29-2008, 11:30 AM
