Thread: Pulsating idle
Results 1 to 6 of 6
  1. #1 Pulsating idle
    Temple Pa
    I have a 96 GP SE 3.4 that i just picked up for $400. It has 88k on it and it has sat for 1 1/2 yrs. The car is not registered yet due to it needs brakes all around. Anyway, When I start it the idle is pulsating almost like a bad MAF. The exhaust is also very quiet and constant moisture an steam emiting from tail pipes. Now the check engine light just started to light. I don't have a scanner to read the codes. Is it possible that the MAF is bad or could the exhaust be that water logged that the motor is not exhausting properly. I am not new to the world of automobiles and i do all my own work. Just looking for some help diagnosing. Thanks in advance .
    Slappy
  2. #2 Re: Pulsating idle
    Temple Pa
    I guess nobody can give any insight on this issue. Thanks for the help.
    Slappy
  3. #3 Re: Pulsating idle
    Florida
    The cat may be clogged/deteriorated so badly that it's choking the engine, sending crazy signals from the O2 sensor to the computer, causing it to surge.
    It could also be a bad maf, just unplug the maf, and restart the car and see if it's any better, if not it's probably the Cat.
  4. #4 Re: Pulsating idle
    Nov 2009
    Grand haven
    Get someone to help you read or pull the codes. Need more info on what is going on when you are driving the car ( spit sputter dies).
  5. #5 Re: Pulsating idle
    Pennsylvania
    clean your maf with some maf cleaner spray, clean your throttle body with throttle body cleaner spray, put in fresh spark plugs, fresh gas (how long's the gas been sitting in the tank?)
  6. #6 Re: Pulsating idle
    Temple Pa
    Well unplugging the MAF made no difference in the running of the car. Will have to clean it because it does look dirty. Also the exhaust does flow but smells like real bad like alot of moisture. Today I had it running and it was 90 out and you could still see exhaust moisture. I think I will be replacing the exhaust.
    Also, on the 3.4 ltr, there is a canister type thing under the airbox. It looks like it attaches to the trans but has a fuel line or a fuel breather line coming off it. what is this?
    Slappy
  1. 91 GP rough idle
    By Juanmiguel in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-04-2010, 11:07 PM
  2. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  3. Rough Idle
    By hacket in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-29-2009, 02:39 PM
  4. pulsating lights
    By 98 GT in forum General Tech Discussion
    Last Post: 02-23-2009, 12:20 AM
  5. pulsating of the rpms MODDED
    By rczzv in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-30-2008, 11:40 PM
