Thread: 1994 gtp cooling fans not working
Results 1 to 4 of 4
  1. #1 1994 gtp cooling fans not working
    SE Level Member almighty's Avatar
    northern illinois
    first question is where is the coolant temp sensor, the gauge works but im not sure if it has 2 sensors 1 for fan 1 for gauge,
    also the fans do not turn on with the AC on, so any help would be welcome
  2. #2 Re: 1994 gtp cooling fans not working
    Feb 2010
    North Dakota
    If i remember right the temp sensor is by the throttle body and by the thermostat on the intake.
  3. #3 Re: 1994 gtp cooling fans not working
    SE Level Member paulygp09's Avatar
    Minnesota
    it is on the bottom of the lower intake manifold below the throttle body.. good luck getting to that, its a major pain in the a$$
  4. #4 Re: 1994 gtp cooling fans not working
    Feb 2010
    North Dakota
    Thats for sure its a major pain in the a$$
  1. Cooling Fans not kicking on.
    By kaylin4u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2013, 12:07 PM
  2. PCM 180 thermostat Fans not working right
    By 04intimidatorSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2010, 11:52 PM
  3. 1994 Gp
    By Orbital431 in forum Visual/Body Modifications
    Last Post: 09-10-2009, 08:10 PM
  4. Cooling fans only work with ac
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2009, 08:54 AM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
