Thread: need help!!
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 need help!!
    Mar 2015
    Tyler Texas
    I have a 98 grand prix se 3.1 L V6. Recently the intake manifold and head gaskets blew. I have replaced both and a few parts that were worn or I broke during the process. After reassembling the motor I cannot get her to start. Ive checked for fuel, spark, and the starter.. all are good. What else could be the cause? Keep in mind that I have never done a fix of this size. Just recently got into working on cars. any help would be appreciated.
  2. #2 Re: need help!!
    will it crank?
  3. #3 Re: need help!!
    Firing order incorrect?
  4. #4 Re: need help!!
    Mar 2015
    Tyler Texas
    Yeah it cranks but wont turn over. Only a back fire every so often. And yes the firing order is correct. Could it be jumped timing?
  5. #5 Re: need help!!
    wheres the back fire coming from? if its the out the TB thats a timing or plug wires are on wrong.
  6. #6 Re: need help!!
    Cylinder 1 is on the rear, so 1,3,5. Not saying you are wrong but alot of people think it's like a 3800 were cylinder 1 is on the front bank.
    It's a timing chain motor, very very unlikely that it jumped time. It would have snapped the chain if anything.
  7. #7 Re: need help!!
    Mar 2015
    Tyler Texas
    Ok. Yeah. I know 1 3 5 is on the back. The backfire is coming from under the hood for sure.
  8. #8 Re: need help!!
    Mar 2015
    Tyler Texas
    Would the pistons still move if the chain is broken?
  9. #9 Re: need help!!
    Yes, just the cam wouldnt.
  10. #10 Re: need help!!
    pistons sill move, broken chain, the rockers would stop moving.
  11. #11 Re: need help!!
    Mar 2015
    Tyler Texas
    Rockers move for sure. Could the spark plug gap cause it to not turn over? Like I said, im new to this and learning as I go. And I really appreciate all your Input
  12. #12 Re: need help!!
    Mar 2015
    Tyler Texas
    The camshaft position sensor is the problem I think.. the wires are exposed.
  13. #13 Re: need help!!
    id double check all your plugs are back where they belong, re check the plug wires for sure.
    did you check for spark and saw spark? and theres fuel to the rail too you said right?
  14. #14 Re: need help!!
    Quote Originally Posted by Jeremey Souders View Post
    that will do it. you can take that pig tail off cut the wires off and solder in new wire. you need to cut back the old wire till you get to clean shinny copper wire. dont try to solder to dirty tarnished wire, it wont solder well at all.
    if theres not enough wire to solder to you can buy a new pig tail for it and solder that on.
  15. #15 Re: need help!!
    Mar 2015
    Tyler Texas
    Im about to put it back on and see what happens. Cleaned all the wires and re wrapped them. It ohms so hopefully it works will update shortly.
  16. #16 Re: need help!!
    Mar 2015
    Tyler Texas
    Ok that didnt do it... gona re check plug wires. Unless the sensor itself is bad.. I dont know what else it could be.
  17. #17 Re: need help!!
    Mar 2015
    Tyler Texas
    Calling it a night. It still wont turn over. Double checked plugs and wires. All sparked. The number 5 wire when I pulled it out the connector was still on the plug not in the wire. Still got spark though.
    BACK STORY.
    It had been overheating for a while. To the point it would shut down before I could pull safely off the road. When it finally died the last time there was oil and coolant mix all over the motor. Thats what led to me replacing the gaskets.
  18. #18 Re: need help!!
    Welp, other things off hand I'd do it unplug the MAF and try starting it.
    Spraying brake cleaner down the throttle body and see if it will start with a boost from that.
    Double check all IGN fuses.
  19. #19 Re: need help!!
    Mar 2015
    Tyler Texas
    Ive tried spraying starter fluid into the air flow. Got nothing. What would unplugging the MAP do?.
  20. #20 Re: need help!!
    if it dont fire up with starting fluid sprayed in the tb, its a spark problem of some kind.
    its the maf you would unplug. some times a bad maf can do this. unplugging it put the car in closed loop, aka pre set setting the engine runs off of.
