Thread: Oil? Power steering fluid? leaking from inner tie rod boot - What cuold be the cause?
Results 1 to 10 of 10
  1. #1 Oil? Power steering fluid? leaking from inner tie rod boot - What cuold be the cause?
    Boston, MA
    Hey guys,
    I have oil? or power steering fluid? leaking from my passenger side inner tie rod boot. I found a tear in the inner tie rod boot, but is there something else wrong if it’s leaking oil from that tear? What could it be?
    It’s a 2001 GP 3.1L V6
    2001 Pontiac Grand Prix SE, 3.1L
  2. #2 Re: Oil? Power steering fluid? leaking from inner tie rod boot - What cuold be the ca
    If it's leaking there, the rack seals have likely blown.
  3. #3 Re: Oil? Power steering fluid? leaking from inner tie rod boot - What cuold be the ca
    Boston, MA
    Can this be repaired with a repair seal kit or is a replacement rack and pinion unit needed?
  4. #4 Re: Oil? Power steering fluid? leaking from inner tie rod boot - What cuold be the ca
    new rack time.
  5. #5 Re: Oil? Power steering fluid? leaking from inner tie rod boot - What cuold be the ca
    Boston, MA
    new rack time.
    No way to fix without replacing this?
  6. #6 Re: Oil? Power steering fluid? leaking from inner tie rod boot - What cuold be the ca
    not worth it really. find a used one or a manufactured one.
    if its just a small leak still you can try some power steering stop leak, that may get you by for a while. but once it starts leak from the boots its just about over.
    those boots are dust boots, supposed to be dry inside.
  7. #7 Re: Oil? Power steering fluid? leaking from inner tie rod boot - What cuold be the ca
    Boston, MA
    Is the rack tough to replace? Any difficult bolts, nuts, or lines to get at? Thanks.
  8. #8 Re: Oil? Power steering fluid? leaking from inner tie rod boot - What cuold be the ca
    truth is it sucks. but not the worst job ive done to a car.
    its like a 22 bolt job, 10 of them are lug nuts, its just tight areas your working in.
    heres a pretty good how to. http://www.grandprix.net/forum/ubbth...at&Number=8020
    the only parts i don't do is to take the master off and air box. you can get to those 2 lines on the rack from under the car just as easy.
  9. #9 Re: Oil? Power steering fluid? leaking from inner tie rod boot - What cuold be the ca
    Boston, MA
    just replaced the rack and pinion unit, ended up buying a used one for $ 40.00, got done today, but started yesterday in the driveway
    the hardest part for me was during the removal of the old unit, spent like 4 hours trying to remove the stupid fitting on one of the power steering hard lines, tried every kind of wrench without luck, had very little room to work with, I was fed up, traced the hard line to a rubber line, disconnected from the rubber line instead, so much easier this way, everything lined up for me during the installation
    during this job I learned that my stabilizer bar was cracked and broke off inside the driver's side bushing, time for a new stabilizer bar
    thanks guys for all your help
  10. #10 Re: Oil? Power steering fluid? leaking from inner tie rod boot - What cuold be the ca
    those are 18 mm nuts. a line wrench works best.
  1. Power Steering Leaking from Tie Rod Boot
    By Demi in forum Introductions/Noob Questions
    Last Post: 10-06-2013, 05:39 PM
  2. power steering fluid
    By tstaller2005 in forum General Tech Discussion
    Last Post: 05-03-2011, 10:34 AM
  3. Power Steering Fluid
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-12-2010, 08:48 PM
  4. Power Steering Fluid
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2010, 01:26 AM
  5. What power steering fluid is best?
    By dl1027 in forum General Tech Discussion
    Last Post: 05-09-2010, 07:55 PM
