Thread: Oil? Power steering fluid? leaking from inner tie rod boot - What cuold be the cause?
Results 1 to 10 of 10
  1. #1 Re: Oil? Power steering fluid? leaking from inner tie rod boot - What cuold be the ca
    Boston, MA
    just replaced the rack and pinion unit, ended up buying a used one for $ 40.00, got done today, but started yesterday in the driveway
    the hardest part for me was during the removal of the old unit, spent like 4 hours trying to remove the stupid fitting on one of the power steering hard lines, tried every kind of wrench without luck, had very little room to work with, I was fed up, traced the hard line to a rubber line, disconnected from the rubber line instead, so much easier this way, everything lined up for me during the installation
    during this job I learned that my stabilizer bar was cracked and broke off inside the driver's side bushing, time for a new stabilizer bar
    thanks guys for all your help
    2001 Pontiac Grand Prix SE, 3.1L
  1. Power Steering Leaking from Tie Rod Boot
    By Demi in forum Introductions/Noob Questions
    Last Post: 10-06-2013, 05:39 PM
  2. power steering fluid
    By tstaller2005 in forum General Tech Discussion
    Last Post: 05-03-2011, 10:34 AM
  3. Power Steering Fluid
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-12-2010, 08:48 PM
  4. Power Steering Fluid
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2010, 01:26 AM
  5. What power steering fluid is best?
    By dl1027 in forum General Tech Discussion
    Last Post: 05-09-2010, 07:55 PM
