Thread: Got ****ed in the ass by my Dad
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 104
  1. #1 Got ****ed in the ass by my Dad
    May 2014
    Flint
    Ok so first of all i bought a 2001 grand prix se 3.1L for $2150
    I thought the kid was an alright guy until I noticed one of the windows were held up by a 2x4... he obviously knew that was wrong and didnt tell me so now I wonder what else is wrong with it and I assume the worst
    the speedometer reads 20mph off
    there is oil in the coolant... I dont know if this is residue from a fixed head gasket or if the LIM is eaten away and the oil is leaking into coolant because there is no coolant in the oil.... or if i have a cracked head or block...
    Im planning on doing a flush tomorrow
  2. #2 Re: Got ****ed around on a craigslist deal please help
    why buy a car with a 3100 in it? you broke rule one.
    these engines have head and lim gasket failure all the time. so plan on doing that asap.
    the window regulator is the least of your problems right now.
  3. #3 Re: Got ****ed around on a craigslist deal please help
    May 2014
    Flint
    Because my dad strong armed me into buying it because he drove 30 minutes to see it... I had no say with my money sigh
    Sent from my SM-G900P using Tapatalk
  4. #4 Re: Got ****ed around on a craigslist deal please help
    go tell dad he owes you your money back then lol
    your gonna have to get your hands dirty on this one.
  5. #5 Re: Got ****ed around on a craigslist deal please help
    May 2014
    Flint
    Only 2k not that bad and it runs and drives... Is it possible to replace the gaskets at home without any major equipment? How much do gaskets run? How do I know if it's not a cracked block or such and is indeed gaskets
  6. #6 Re: Got ****ed around on a craigslist deal please help
    if its got coolant in the oil do not drive it. or run it. you;ll spind a bearing and need a whole engine.
    a basic tool set will get the job done. and a torque wrench.
    gaskets and head bolts and fluids around 200 i'd think all and all.
    shop around for the best prices on line for the gaskets. id stick with felpro gasket if you can. advance auto on line, find a discount code for more off, ebay, amazon, rock auto and so on. shop them all find your best prices.
  7. #7 Re: Got ****ed around on a craigslist deal please help
    May 2014
    Flint
    No coolant in oil.
    Oil in coolant
  8. #8 Re: Got ****ed around on a craigslist deal please help
    that cant happen. its impossible.
    dex sludge maybe.
  9. #9 Re: Got ****ed around on a craigslist deal please help
    May 2014
    Flint
    Your saying a blown head gasket can't put oil into your coolant???
  10. #10 Re: Got ****ed around on a craigslist deal please help
    May 2014
    Flint
    It may just be dex sludge it did have green in it and I know the cars come with dex
  11. #11 Re: Got ****ed around on a craigslist deal please help
    it pretty much physically impossible to get oil in the coolant.
    unless you have a oil cooler in your rad, and a doubt you have one of them.
  12. #12 Re: Got ****ed around on a craigslist deal please help
    SWPA
    Quote Originally Posted by timothylockhart View Post
    "Only" 2k? I paid 2k for a running, driving, modded AWD Talon in great shape. You screwed yourself by not doing your homework.
  13. #13 Re: Got ****ed around on a craigslist deal please help
    May 2014
    Flint
    So you think it's sludge then? And a flush should set me straight
  14. #14 Re: Got ****ed around on a craigslist deal please help
    lets hope so. you may want to add some rad flush to it to clean it up better then just a flush.
    is it running hot? leaking coolant? or coolant missing and no leaks? or the check engine light on?
  15. #15 Re: Got ****ed around on a craigslist deal please help
    May 2014
    Flint
    No check engine light... Small power steering leak doesn't run hot that I've noticed hottest I seen was 210 after 30 minutes of driving and on a hot day
  16. #16 Re: Got ****ed around on a craigslist deal please help
    May 2014
    Flint
    There's no way to disable the check engine lights is there? Have an odb2 sensor that won't communicate with ecu on this car but will on another... It is a cheapie from Amazon so it might just be the sensor not liking my car
  17. #17 Re: Got ****ed around on a craigslist deal please help
    check the cig lighter fuse, the obd2 port runs off that fuse. inside fuse box is where to look.
  18. #18 Re: Got ****ed around on a craigslist deal please help
    May 2014
    Flint
    If my cig lighter works odb2 should work to?
  19. #19 Re: Got ****ed around on a craigslist deal please help
    it should, if not check the wires to the port under the dash.
  20. #20 Re: Got ****ed around on a craigslist deal please help
    May 2014
    Flint
    It receives power the sensor does just can't talk to ecu
