Thread: coolant temp sensor
Results 1 to 2 of 2
  1. #1 coolant temp sensor
    Oct 2012
    Atlantic, NC
    Hey guys, new to the site, but having a problem with a 2002 model. My son called me and said his car was running hot, he had taken it to a mechanic who told him it was a head gasket. The intake gaskets were replaced earlier, by who I'm not sure, but I can tell they were replaced. First thing I found was a blockage in the heater core, back flushed it until it ran clear, then flushed the rest of the system. Then pulled the thermostat and checked it, it checked good. Replaced the water pump, just because it was realatively cheap and easy. The radiator fans wern't coming on so I checked the three relays, which all checked good. Next changed the coolant temp sensor, and things got weird. The temp gauge quit working, it just pegs out int the top range, and fans still dont work. If I unplug the harness from the sensor while the car runs the gauge drops to the bottom, and the fans come on. The sensor checks good, as far as the resistance readings go. I looked them up on google and found a pin-out diagram. 5000 ohms, stone cold and drops steadely as it warms up to a few hundred ohms. My question is where do the three wires go from the sensor, I have a green wire with 12V, a yellow wire with 5V and an oarnge wire with 0V. I feel like I need to trace these wires, but was hoping I could get a head start from some experts. Thanks in advance for any help.
    Billy
  2. #2 Re: coolant temp sensor
    Mar 2013
    carlton
    coolant temp sensor 3 wire, same goes right to hot, pegs out temp gauge, within seconds for starting, 3 wire senor is new and ohms fine
    looking for eng wire diagram 3.1L J code eng 2003 GP
    Hays manual useless, useless POS
  1. do i have a clogged injector or a bad coolant temp sensor
    By athalflife3 in forum General Tech Discussion
    Last Post: 07-09-2013, 02:14 AM
  2. Coolant temp sensor question
    By TEK310 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2012, 08:52 AM
  3. Replaced coolant temp sensor and....
    By NerdPower in forum General Grand Prix Discussion
    Last Post: 04-23-2012, 04:38 PM
  4. Where is the coolant temp sensor located?
    By usetaboost in forum General Tech Discussion
    Last Post: 11-26-2010, 06:34 PM
  5. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
