Thread: Lim - 3.1
Results 1 to 18 of 18
  1. #1 Lim - 3.1
    Sep 2011
    Southern Alberta, Canada
    Ok i got most of the to the LIM out, and having problems getting the LIM to loosen up - how many bolts and if all the bolts are out, what is the best way to get the lim seal to release???????
  2. #2 Re: Lim - 3.1
    Sep 2011
    ok I used a skinny wood chisel where the gasket was and was able to pop it free after about 5 min.
  3. #3 Re: Lim - 3.1
    So much fun huh?
  4. #4 Re: Lim - 3.1
    Sep 2011
    it was on - i thought i missed some bolts - nope - just been there so long.
  5. #5 Re: Lim - 3.1
    Make sure you put the pushrods back int he right order. Ugh..different length rods..lol the 3800 seems so much easier.
  6. #6 Re: Lim - 3.1
    Sep 2011
    Thanx - didnt know
  7. #7 Re: Lim - 3.1
    Make sure you clean all the gasket surfaces as well.
    You gonna paint everything while it's off I'm guessing?
    I'd do white...offset all the blue.
  8. #8 Re: Lim - 3.1
    Sep 2011
    Ya i have a pic in my thread
    white - valve covers, plenum - plastic sheild under rad, thermostat housing
    Blue - LIM, steel tube running over LIM
  9. #9 Re: Lim - 3.1
    Sep 2011
    first piece painted
  10. #10 Re: Lim - 3.1
    Looks good make sure you use rtv where the coolant line goes into the lim.
  11. #11 Re: Lim - 3.1
    Sep 2011
    ok - will do
  12. #12 Re: Lim - 3.1
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Quote Originally Posted by Johnalyujs View Post
    I used a thin wooden created developed kind where the gasket was and was able to pop it no cost after about 5 min.Make sure you put the pushrods returning int he right buy. Ugh..different duration allows..lol the 3800 seems so much simpler.
    What.
    GPONA #1 Cyber Bully
  13. #13 Re: Lim - 3.1
    Guy its back together and been running for a while
  14. #14 Re: Lim - 3.1
    Oct 2012
    Beacon, NY
    Where did you get the blue electrical wire tubes? I need some new plastic tubes.
  15. #15 Re: Lim - 3.1
    Sep 2011
    Taylor's convoluted tubing - Parts Source
  16. #16 Re: Lim - 3.1
    Oct 2012
    Beacon, NY
    Quote Originally Posted by heavydtheogre View Post
    Ok because mine look beat up and old from over the years.
  17. #17 Re: Lim - 3.1
    Sep 2011
    Quote Originally Posted by Matthew Mericle View Post
    ya its cheap, and many sizes - i think all of mine cost around $32, and i have extra.
  18. #18 Re: Lim - 3.1
    Oct 2012
    Beacon, NY
    That is pretty damn cheap.
lim
