Thread: UPDATE > High Idle - problem solved - IAC Valve ( Intake Air Control Valve )
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: UPDATE > -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Boston, MA
    UPDATE >
    RPMs drop when putting finger over IAC port inside throttle body, a strong suction is felt on finger.
    Is the problem the IAC Valve?
    2001 Pontiac Grand Prix SE, 3.1L
  2. #22 Re: UPDATE > -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Mar 2012
    NC
    Quote Originally Posted by turboLude View Post
    UPDATE >
    Potentially, but the car should also try to stall with the IAC blocked off.
  3. #23 Re: UPDATE > -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Boston, MA
    It does try to stall when plugging port almost entirely.
    With about 80% of the port blocked off, it idles at around 800 RPM
  4. #24 Re: UPDATE (page 2) > -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Mar 2012
    NC
    Sounds like you may have found the problem.
  5. #25 Re: UPDATE (page 2) > -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Boston, MA
    I hope, but no SES light for bad IAC valve ?
  6. #26 Re: UPDATE (page 2) > -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Mar 2012
    NC
    Your car obviously didn't care for some reason.
  7. #27 Re: UPDATE (page 2) > -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Boston, MA
    Replaced the IAC valve with a new one and problem solved!
    No more high idle.
    Thanks guys.
  1. old people CANNOT drive/park
    By sLpGPGT in forum Off Topic Discussion
    Last Post: 02-11-2012, 05:53 PM
  2. High idle in park and neutral?
    By Injectiongtp in forum General Tech Discussion
    Last Post: 04-18-2011, 05:38 PM
  3. Replies: 7
    Last Post: 07-07-2010, 08:58 AM
  4. 2006 Grand Prix tranny noise in park & neutral
    By stevencharles32 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-16-2009, 12:52 PM
  5. 01 GTP. Car shakes when in Neutral and Park.
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 03:00 AM
