Thread: Antifreeze leak - Still Leaking - Not LIM - New Pics Sept 29 2012
Results 1 to 20 of 32
  1. #1 Antifreeze leak - Still Leaking - Not LIM - New Pics Sept 29 2012
    Sep 2011
    Southern Alberta, Canada
    98 GP SE 3100
    Ok I overfilled the rad overflow - car didnt like it.
    But have taken the pulley off the water pump, no leaks and looks new.
    the antifreeze is near the crank pulley, and behind the engine on the subframe.
    There is no leak behind the power steering pump, or alt, or on the intake - from the top of the crank pulley is really dry.
    Any ideas???
  2. #2 Re: Antifreeze leak
    Sep 2011
    Ok heres a pic of where the antifreeze sits
  3. #3 Re: Antifreeze leak
    LIM gasket could be leaking.
  4. #4 Re: Antifreeze leak
    you also need a new belt.
  5. #5 Re: Antifreeze leak
    Try tightening up the 10 mm bolts on the ends of the LIM and if they are loose then you need to change out the LIM gasket.
  6. #6 Re: Antifreeze leak
    Sep 2011
    ya i know - lots of little cracks.
  7. #7 Re: Antifreeze leak
    Sep 2011
    OK.
  8. #8 Re: Antifreeze leak
    Sep 2011
    Think i found the leak - the overflow,
    Im going to take out and see.
  9. #9 Re: Antifreeze leak
    Sep 2011
    OK checked the overflow and no breakage - sat on counter overnight half full - water - no leak
    Put it back in the car, fill to line with antifreeze/water mixture, and gone within a few hours.
    And while the overflow was empty in the car for the past week, antifeeze in the rad stayed the same height.
    And cant find any liquid on the drivers sine of the car. - the antifreeze is on the passside as in pic.
    Makes no sense
    I need more ideas - and no bolts are loose on the LIM.
  10. #10 Re: Antifreeze leak
    London Ont, Canada
    check all your hoses for cracks/holes.. make sure they are tight and not loose?
  11. #11 Re: Antifreeze leak
    Sep 2011
    Ya checked, and no leaks - and no wet spots on top or sides of motor, its just a littl ewet near the crank pully and lower, thats it.
    and i dont loose any antifreeze out of rad even with overflow empty.
  12. #12 Re: Antifreeze leak
    get some engine cleaner and clean that whole area up and see what hits it down the road, this could just be old oil from who knows where down there.
  13. #13 Re: Antifreeze leak
    Could be lim gasket leaking. They like to leak out the sides.
  14. #14 Re: Antifreeze leak
    Aug 2011
    'Merica
    Junk car and buy a GT or a GTP or just junk car
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Check under the thermostat, idk if that applies to the 3100, but full that up if you can't see fluid when you pop it off.
    If that doesn't do it, just drain everything flush and refill. See if it still leaks.
  16. #16 Re: Antifreeze leak - Still Leaking - Not LIM - New Pics Sept 29 2012
    Sep 2011
    Ok Have more Pics - Still leaking on rear
    First pics showing LIM and no leaks
  17. #17 Re: Antifreeze leak - Still Leaking - Not LIM - New Pics Sept 29 2012
    Sep 2011
    OK now where its wet
  18. #18 Re: Antifreeze leak - Still Leaking - Not LIM - New Pics Sept 29 2012
    im not familiar with the 3100 at all, so what pulley is this, the one thats wet behind it. not the tensioner.
  19. #19 Re: Antifreeze leak - Still Leaking - Not LIM - New Pics Sept 29 2012
    Sep 2011
    I dont think replacing the LIM was a waste of time, but dont think it was leaking. But was bad.
  20. #20 Re: Antifreeze leak - Still Leaking - Not LIM - New Pics Sept 29 2012
    Sep 2011
    ya thats the tensioner and the crank at the bottom.
  1. LIM antifreeze leak
    By 2004GrandPrixGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-28-2012, 10:49 PM
  2. antifreeze leak question
    By gentrymartin in forum General Tech Discussion
    Last Post: 03-12-2012, 02:37 PM
  3. antifreeze leak
    By dirtdriver11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2011, 08:50 AM
  4. antifreeze leak..
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:36 PM
  5. Antifreeze leak...
    By bowtechguy in forum General Tech Discussion
    Last Post: 03-23-2009, 07:24 AM
