Alright.. I've done a 3400 top end swap in my 98 GP with a 3100 block.. EGR's are different and my Chilton wiring diagram only lists the colors of the wires that are leading to the EGR connector.
They're labeled on the EGR as follows: ..A.... B...... C.. D... E
Wire colors are:................................ R.. BR/W.. BR. GY. GY
I cut the 'E' Gray wire and no longer have MIL codes for EGR low voltage but still have EGR codes for non-op. The manifold port is blocked and EGR tube cut. Having the 'E' wire cut disables the coil inside the EGR.
I am asking for any input to find a way to fake the computer into thinking the EGR is still operating with out having to flash the PCM. Any ideas?
