Thread: EGR delete w/o PCM Flash
Results 1 to 8 of 8
  1. #1 Re: EGR delete w/o PCM Flash
    Apr 2012
    MN
    If you delete the codes in the computer then you typically should be set. Another item to do is set the EGR minimum test temperature to the max setting. In HPT it's 284F. That keeps the test from ever needing to be run.
    I have verified this works.
    Thanks for the suggestion, but this thread is titled "EGR Delete W/O PCM Flash"
    >>Also the OBD computer does a run-up test under initial engine start and without a complete circuit it will pop a code and illuminate the MIL<<
  1. official switchback/led bulb hyperflash fix and sidemarker flash delete.
    Last Post: 04-08-2018, 02:54 PM
  2. Disabling Headlight Flash for HID's
    By skidoojames151 in forum How To Write-Ups/Tech Tips
    Last Post: 06-14-2012, 12:28 PM
  3. hyperflash fix and sidemarker flash delete.
    By BoostJunki3 in forum How To Write-Ups/Tech Tips
    Last Post: 08-16-2011, 04:48 PM
  4. flash floods
    By oneil.GTP in forum Off Topic Discussion
    Last Post: 05-18-2010, 12:22 AM
  5. Top Swap Re Flash problem
    By MNGP07 in forum PCM Tuning
    Last Post: 03-22-2009, 08:02 PM
