Thread: intake manifold gasket or head gasket
Results 1 to 11 of 11
  1. #1 intake manifold gasket or head gasket
    House springs missouri
    I've been losing coolant in my 1995 grand prix 3100 in this past weekend my heater core went out so I but I passed it and now there's coolant in my oil I know that usually means a head gasket but is there anyway it could be and intake manifold and if it is a head gasket should I use a stop a leak like steel sea or should I go to the trouble of replacing the head gasket
  2. #2 Re: intake manifold gasket or head gasket
    I meant but I bypassed it
  3. #3 Re: intake manifold gasket or head gasket
    new britain, ct
    coolant in your oil is probably a lower intake manifold gasket. also known as a LIM. its a pretty extensive job.
    07 Black GXP.
  4. #4 Re: intake manifold gasket or head gasket
    Ok thanks
  5. #5 Re: intake manifold gasket or head gasket
    St. Louis
    Yep. Replace the LIM gasket. And I wouldn't be driving it since you know for sure you have coolant in the oil. You are just a spun bearing waiting to happen, then the leak won't matter much. And no, don't dump stop leak in it, as it will clog the heater core and rad as well. Never a good idea.
  6. #6 Re: intake manifold gasket or head gasket
    It's not to bad of a job only takes about 3 times as long as doing it on a 3800. It's about a $100 fix if your doing it yourself.
  7. #7 Re: intake manifold gasket or head gasket
    A ton of swearing. Actually..you should get a book, you'll swear so much you need some new material. Enjoy the alternator..that's a funny one..not even long enough wires to unplug it decently.
  8. #8 Re: intake manifold gasket or head gasket
    does the 3100 have a timing belt or timing chain
  9. #9 Re: intake manifold gasket or head gasket
    chain i'm pretty sure.
  10. #10 Re: intake manifold gasket or head gasket
    Troy OH
    chain for sure.
  11. #11 Re: intake manifold gasket or head gasket
    ok thank you guys
  1. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  2. the best lower intake manifold gasket?
    By bps02gtp in forum General Tech Discussion
    Last Post: 06-24-2011, 05:04 PM
  3. Intake Manifold Gasket/seal
    By ssm90GT in forum General Tech Discussion
    Last Post: 12-12-2009, 03:06 AM
  4. Intake manifold end cap gasket
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2009, 07:01 PM
  5. Intake manifold gasket
    By rudyram118 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2008, 09:38 PM
