Thread: {Update 9-4-12 } I am pretty sure my motor is gone
Results 1 to 13 of 13
  1. #1 {Update 9-4-12 } I am pretty sure my motor is gone
    Nov 2010
    Missouri
    DSCN0725 - YouTube
    UPDATE!!!! There was a valve the dropped in the head. Leaking coolant in one of the cylinders, 2 cylinders had no compression. I found this out a few days later. The knocking noise was coming from a rocker in the head. The bottom end of the motor was still flawless. I never fixed the car. I drove it for another 5 thousand miles running that way. When I had the chance I bought a new car. A 2001 Pontiac grand prix gtp. The new car is pretty amazing. It is white with 150,00 miles. I will post pictures of the car today, I bought the car over 1 month ago.
    last night driving home my car tried to stall a few times at a red light and my check engine last was flashing red and at different times yellow. Well normally my check engine light is always on because of my exhaust leak. well anyways I drive another block to get it to a gas station. Well I uploaded a video on there for you guys to see. If you need anymore I will be more than glad to get some.
    The car details:
    03 grand prix
    all stock
    209,000 miles
    last tune up in march
    fresh oil change less than 2000 miles ago
    new radiator 2000 miles ago
    tranny has been going out.
    the only thing done to the car is wheels 18's on a 245/45 tire
  2. #2 Re: I am pretty sure my motor is gone
    Charles City, IA
    Check the oil pressure. Sounds like you spun a bearing.
    SMGPFC Two Nipple General
  3. #3 Re: I am pretty sure my motor is gone
    sounds internal.
    spun bearing likely, see if the oil has tons of metal sparkles in it.
  4. #4 Re: I am pretty sure my motor is gone
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    Your motor is gone?, did you look under the bed, most things end up under the bed.
  5. #5 Re: I am pretty sure my motor is gone
    Nov 2010
    Missouri
    No metal shavings on the dipstick. But there is a def. miss. as well. If the motor is gone its time for a milzy motorsports 3.8SC conversion oh and replaced the lower intake gasket and all the hoses and radiator in the car when we did the tune up in March. oh to clarify things I have been through two radiators since March.
  6. #6 Re: I am pretty sure my motor is gone
    Why?
  7. #7 Re: I am pretty sure my motor is gone
    Nov 2010
    Missouri
    Why on what?
  8. #8 Re: I am pretty sure my motor is gone
    Why have you been through 2 radiators?
  9. #9 Re: I am pretty sure my motor is gone
    And why spend all that money at Milzy?
  10. #10 Re: I am pretty sure my motor is gone
    Nov 2010
    Missouri
    true on milzy I could get everything cheaper else where. When we did the LIM I went ahead and replaced the radiator with the hoses and everything else in the cooling system. I bought the car after the previous owner blew it. The oil was mixing with the radiator it was all boiled and gunked up on the radiator cap but never had coolant in the pan. The second time I replaced it one of the connectors were leaking on the radiator.
  11. #11 Re: {Update 9-4-12 } I am pretty sure my motor is gone
    Nov 2010
    Missouri
    Read the top post for update.
  12. #12 Re: {Update 9-4-12 } I am pretty sure my motor is gone
    Quote Originally Posted by arcadeguest View Post
    The overlay is red. There isn't multiple colors of check engine lights.
    Post is pretty damn confusing. Because you also can't run on 3 cylinders well enough to drive 5 miles, skip the thought of 5,000.
  13. #13 Re: {Update 9-4-12 } I am pretty sure my motor is gone
    Nov 2010
    Missouri
    Im not sure how I did it. I got rid of the car at 214 thousand. Im also color blind so the red kinda screws with me.
  1. pretty excited
    By gtcoup in forum Off Topic Discussion
    Last Post: 02-17-2011, 08:50 PM
  2. Back to pretty :)
    By Ricky21 in forum Visual/Body Modifications
    Last Post: 05-20-2010, 11:03 PM
  3. im pretty much anti-20's but
    By TorqueAutoMotiv in forum Tires & Wheels
    Last Post: 05-12-2010, 10:03 PM
  4. New GXP owner ... well, pretty soon
    By BryanB in forum Introductions/Noob Questions
    Last Post: 01-18-2010, 07:52 PM
  5. pretty sure it was a GXP
    By gtpinsc in forum Track Sessions and Kills
    Last Post: 10-02-2008, 11:34 AM
