Thread: bouncing Rpms, then stalls."update with Fix"
Results 1 to 13 of 13
  1. #1 bouncing Rpms, then stalls."update with Fix"
    GT Level Member thedudeSE's Avatar
    Rio grande city texas
    My car just recently started acting up, I noticed the rpms keep bouncing up when im in a complete stop or driving slow, most of the times it stalls..... I have changed the oil and filter, new sparks and wires, cleand the air filter the MAF and TB, and seafomed it, still nothing has changed, I know my cat was starting to get clogged, could that be the problem.
    I scanned and these are the codes I got.
    p0171,p0102,p01443,p0650.
    any help would be greatly appreciated.
    **** well I tried everything, I changed the cat, egr valve, fixed all the vacume leaks, replaced MAF, and changed the plugs and wires, turns out the fix was a new battery, my old battery was not giving enough voltage, which coused my Rpm's to bounce up and down and eventually stall......
    so hopefully this is the same fix for everyone else with the same problem.***
    Dont walk around like your the king of the world..... Walk around like you dont give a fu** who the king of the world is.
    smgpfc epic member# 5
  2. #2 Re: bouncing Rpms, then stalls.
    GTX Level Member bandits grand prix's Avatar
    Jul 2010
    connecticut
    is your egr valve going?
  3. #3 Re: bouncing Rpms, then stalls.
    how would I check......."still learning"
  4. #4 Re: bouncing Rpms, then stalls.
    Jul 2010
    connecticut
    im not sure how to check it, because i just changed it without even checking it.
    http://images.oreillyauto.com/parts/...pi/29138-1.jpg
    How to Change an EGR Valve on a 2001 Pontiac Grand Prix | eHow.com
  5. #5 Re: bouncing Rpms, then stalls.
    unplug it but i dont think thats the problem
    mtl is vacuum related
    SMGPFC Member #10
  6. #6 Re: bouncing Rpms, then stalls.
    Jul 2010
    connecticut
    thats what it looks like and thats how to clean or replace it
  7. #7 Re: bouncing Rpms, then stalls.
    Il try it out, could a vaccume leak also couse my symptoms.
  8. #8 Re: bouncing Rpms, then stalls.
    yes, 3100 arnt running right if there not leaking,,
    SMGPFC Member #10
  9. #9 Re: bouncing Rpms, then stalls.
    I don't know if this matters but I forget to say that the Rpms starting bouncing back and forth between 500-1000 Rpms, if it goes under 500rpms it will stall
  10. #10 Re: bouncing Rpms, then stalls.
    GT Level Member popeyenate's Avatar
    Jan 2009
    san diego
    maybe the egr pipe is cracked causing the vac leak? my car has loose one, and mine does same thing...gotta fix so i can drive
  11. #11 Re: bouncing Rpms, then stalls.
    alright then il try the egr fix, thank you guys for helping out, il update if the problem gets fixed or not.
  12. #12 Re: bouncing Rpms, then stalls.
    ok guys I havent changed the egr valve, but I did find some vacume leaks, so do I just replace the lines or is there a way to plug them up or something.
  13. #13 Re: bouncing Rpms, then stalls.
    depends on the lines, some time you can get a way with just tapeing over the leak and others you just have to replace
    SMGPFC Member #10
  1. WOT Hesitates then chirps 2 & 3/ stalls around 2200 rpms?
    By Explicit_Spade in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-08-2011, 05:21 PM
  2. Exhaust is bouncing...HELP!!!
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 07-12-2010, 02:55 PM
  3. Bouncing projectors
    By Ricky21 in forum General Tech Discussion
    Last Post: 05-19-2010, 08:34 PM
  4. Fixing Headlights' Bouncing
    By vega in forum Visual/Body Modifications
    Last Post: 02-20-2010, 07:31 PM
  5. 94 GTP gas smell and bouncing idle
    By rw53104 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 02-17-2010, 02:21 PM
