Thread: Stumble after it rains
Results 1 to 10 of 10
  1. #1 Stumble after it rains
    SE Level Member Blackbird87's Avatar
    Dec 2010
    Chicago
    Im just going to assume that water is getting in somewhere but i dont know where or how. Car is a 99 gp no mods. First started when i drove through a puddle (nothing big) and the car would only rev to 2k and start missing, towed it home and it drove fine. Now it sometimes does it when in rains hard, The car will drive just fine but will break up at 2k. ive checked the intake and all vacuum lines but im at a loss
  2. #2 Re: Stumble after it rains
    check for leaks and broken hose(s) and check the intake and make sure that is still all good
    SMGPFC Member #10
  3. #3 Re: Stumble after it rains
    Dec 2010
    Chicago
    ive checked all of that but will check it again. I have no idea where it could be getting in. Could it be a sensor getting wet
  4. #4 Re: Stumble after it rains
    just throwing this out there, but how are your plug wires? if they are real old (hard/cracks) they wont work well wet. or you could have bare wires at the plugs of some key sensors. (bad pig tails)
    i used to spray my trucks wires down with wd-40 when i was flood running, it helps to keep them running in deep water. if it died in the water, we would pull it out, re spray the engine with wd-40 and they always started back up after doing so.
    same symptoms as you, fighting to get any rpm out of it, and stall at idol, spray it and it would run perfect again.
  5. #5 Re: Stumble after it rains
    Dec 2010
    Chicago
    Plug wires are new. Im not getting an cel either. I think i might spray the engine compartment one spot at a time to try and pinpoint an area to start from
  6. #6 Re: Stumble after it rains
    Quote Originally Posted by Blackbird87 View Post
    Thats how I find these issues.
  7. #7 Re: Stumble after it rains
    SE Level Member 3100sfi's Avatar
    Jul 2011
    Canada
    1996 Pontiac Grand Prix SE coupe - white - stock until something breaks
  8. #8 Re: Stumble after it rains
    Dec 2010
    Chicago
    Quote Originally Posted by 3100sfi View Post
    Wouldnt it miss at idle. it literally feels like hitting a rev limiter
  9. #9 Re: Stumble after it rains
    PA
    When was the last time you changed your air filter?
    2001 GSE
  10. #10 Re: Stumble after it rains
    Dec 2010
    Chicago
    5 months. The first this happened I ruled out the filter but opening the air box and reving it
  1. HELP! Engine stumble
    By dagofast2112 in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-20-2011, 06:26 PM
  2. Every time it rains
    By zildjian102 in forum General Tech Discussion
    Last Post: 04-26-2011, 11:30 PM
  3. Misfire, Stumble
    By Bill3256 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-08-2010, 09:19 PM
  4. Hesitation and Stumble
    Last Post: 05-08-2010, 06:54 PM
  5. Stumble at idle
    By lowdeuce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2008, 10:26 PM
