Thread: vacuum leak
Results 1 to 5 of 5
  1. #1 vacuum leak
    Jul 2008
    brunswick,ga
    i just put my whole engine bac together an it crunk up an has a really high idle probaly around 3 grand my tac didnt work either for some reason so im just guessing but it nevers drops down i think its a vacuum leak in the intake manifold im so tired of tearing this thing apart any help,tips,suggestions would b appreciated im ready to drive again
  2. #2 Re: vacuum leak
    I live here. UR LOSN's Avatar
    Rockford, IL
    what year of car do you have? they had changed the vacuum line layout over the years.....
    Do you hear a sucking sound while it is running at all? check to make sure the TB is closing....
    at the passenger rear of the upper intake there should be a vacuum port....make sure that is plugged with the factory line, or the factory plug.
  3. #3 Re: vacuum leak
    Jul 2008
    brunswick,ga
    2002 gp se 3.1 i dont really hear nothing the tb is closing an yea its a little vac line in the top left corner its hooked up i guess ima start tearing it apart tomorrow figure something out
  4. #4 Re: vacuum leak
    Rockford, IL
    check all the lines for cracks, old age....and replace them as needed. If you have the chilton book for your vehicle, I would go over everything you did. see if you dont remember hooking something back up.........
    do one thing at a time, and dont rush. the 3.1 can be a pain, butit means well!!!!
  5. #5 Re: vacuum leak
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    Quote Originally Posted by UR LOSN View Post
    3.1 arnt that bad but theyy are fun to do intake gaskets on. but yea make sure tha vacumm booster is pluged in that can do it casue for it to idle that high it has to be pretty large.
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  1. Bad vacuum leak
    By boredout in forum General Tech Discussion
    Last Post: 07-14-2008, 02:21 AM
  2. Coolant leak
    By jdgaetan in forum General Tech Discussion
    Last Post: 05-31-2008, 03:24 AM
  3. What is Vacuum on a boost gauge ??
    Last Post: 04-07-2008, 12:54 PM
  4. Oil leak
    By fiveinthelive in forum General Tech Discussion
    Last Post: 03-11-2008, 09:35 AM
  5. Oil leak problem
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 05:24 AM
