Thread: Fuel injectors stuck in intake manifold
Results 1 to 9 of 9
  1. #1 Fuel injectors stuck in intake manifold
    I can't get the damn fuel injectors out of the intake manifold i'm working on a 00 malibu and it's pissing me off. I was taking it off and only one came out with the fuel rail so i'm hoping they all connect back up alright with no problem. Any input will be appreciated. Thanks.
  2. #2 Re: Fuel injectors stuck in intake manifold
    twist then pull?
  3. #3 Re: Fuel injectors stuck in intake manifold
    no go i put pb blaster all over them and still nothing i can get them to twist in there a little bit but only two of them are moving.
  4. #4 Re: Fuel injectors stuck in intake manifold
    SWPA
    Sounds like the orings are swollen and hard as rocks. Hopefully you have new orings. Pull hard as you can straight up.
  5. #5 Re: Fuel injectors stuck in intake manifold
    if you have a scalpel you can try cutting the o rings.
  6. #6 Re: Fuel injectors stuck in intake manifold
    i saw online a fuel injector removal tool, if i can't get them out i might just tow it down the street and have a garage take them out it should only cost a few buck and save me a big headache.
  7. #7 Re: Fuel injectors stuck in intake manifold
    Charles City, IA
    Put the fuel rail back on them and then use a pry bar to pop the assembly up.
    SMGPFC Two Nipple General
  8. #8 Re: Fuel injectors stuck in intake manifold
    I just unplugged them and moved everything out of the way. But then my daughter woke up from her nap so i had to stop but i think it should go a little more smoothly now..... I hope
  9. #9 Re: Fuel injectors stuck in intake manifold
    Got it all done last week but the girl called me and said that today her car wouldn't start so i went over there and it started off starting fluid and ran ok but it wasn't right. So i turned it off and restarted it about 6-7 times then i left and she called me about 10 min later and said it wouldn't start again. I know it's fuel related and the only thing i did diff than it was was not putting the clips on the injectors where they clip to the fuel rail. Please help if you can. thanks
  1. intake manifold
    By eightballe in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2011, 01:30 PM
  2. Which intake manifold is better?
    By ya61x in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-12-2010, 11:51 PM
  3. Intake manifold
    By joesforspeed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 12:15 PM
  4. Intake manifold
    By joesforspeed in forum Turbo
    Last Post: 10-21-2008, 03:55 AM
