Thread: 3100 high idle. nothing is helping.
Results 1 to 4 of 4
  1. #1 3100 high idle. nothing is helping.
    Dec 2010
    north branch mn usa
    hey guys im new to gm vehicles and just bought a 96 grand prix with the 3100 for a dd. has 105k on it and intake gasket allready done and ran great when i bought it. i dorve it home and everything was fine. when i went to drive it in the morn it had a high idle around 2k and check engine was on. i ran the codes. i got a tps(weak signal i belive) transmission sliping(which was wierd cause the trans was shifting great and not slipping) and speedo was off by 0-1 percent. so i pulled the throttle body, cleaned it and replaces the iacv and tps. still the same high idle. aany help would be great.
  2. #2 Re: 3100 high idle. nothing is helping.
    GT Level Member Lvgrandprix2003's Avatar
    Cincinnati
    I don't think GM has a Idle air sensor like dodge and ford, so it may be your Mass air Flow that is the issue.
  3. #3 Re: 3100 high idle. nothing is helping.
    Jan 2009
    On This Planet...
    if the iac is clean and working, than maybe you have a vacuum leak...
    try to hear it.
  4. #4 Re: 3100 high idle. nothing is helping.
    Indianapolis
    I had a similar idle problem on my 3.1 Beretta. It's almost certainly a vacuum leak. In my particular instance the scanner said that there's a grommet that can be sucked into the manifold near the throttle body. Can't remember exactly which one, IAC I believe. At any rate, click this link
    3.4L and 3.1L V6 Engine Sensor Locations Pictures and Repair Help
    The area I'm talking about is labeled 2 for the IAC. You can see the bracket in the picture. I think one bolt holds it in, check that area for vacuum leaks. We fixed mine by cutting the end off a spark plug wire, was a perfect fit for the tube going in there. Ghetto but w/e, it fixed it. You'll probably have to d/c the battery for a minute or so in order for the computer to relearn how to idle.
  1. Need help with my high idle
    By GPMANE97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2010, 09:11 PM
  2. High idle?
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 02:14 AM
  3. 98 GTP high idle problem
    By mikegtp in forum General Tech Discussion
    Last Post: 10-09-2009, 02:05 PM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  5. 1999 SE 3100 Replaced engine, Surging at idle
    By socalchlln in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-09-2009, 10:09 PM
