after the camshaft has been replaced, i found that the camshaft sensor is broken. totally.
i took another sensor from an overheated engine (same kind as mine), but my engine still won`t run smooth.
i`ve checked the output from the cam sensor- no signal. (the green wire) although it gets good ground and voltage (black and red wire).
oh, and i don`t have a code scanner. yet.
could it be a faulty cam sensor?
could it be the crank sensor as well? (when i`ve disconnected the crank sensor- the engine died. when i`ve disconnected the cam sensor- nothing happened...)
thanks!
