Thread: 1991 grand prix starts then dies after five minutes
Results 1 to 2 of 2
  1. #1 1991 grand prix starts then dies after five minutes
    north idaho
    yea so my 1991 grand prix se, 3.1L recently died on me while driving. checked spark immediatly after and had none, it will turn over but won't start. everything else works on it. i hooked a computer up to it and it gave me code 42- electronic spark timing monitor error and code 34 mas / map sensor too low. i've changed the crank sensor in it (but i hear there's two?) and still the same thing, when i let it cool down it will start right up for five minutes then die starting the process all over again. any ideas what it could be?
  2. #2 Re: 1991 grand prix starts then dies after five minutes
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    there is only 1 crank sensor. i would say it is the ignition control module under the coil packs in the front bottom of the engine.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  1. 97 supercharged grand prix v6 dies after about 15 minutes of driving
    By emericadrew in forum General Tech Discussion
    Last Post: 09-06-2009, 03:42 PM
  2. 1991 Grand prix issues- HELP ME
    By Fastline42 in forum General Tech Discussion
    Last Post: 06-25-2009, 02:20 PM
  3. 90 Grand Prix starts, then dies
    By Fishhead5 in forum General Tech Discussion
    Last Post: 06-05-2009, 10:35 AM
  4. 1991 grand prix od?
    By thenervemann in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-13-2009, 02:25 PM
