Thread: Clicking/knocking under heavy acceleration
Results 1 to 5 of 5
  1. #1 Clicking/knocking under heavy acceleration
    GT Level Member Hpiracr28's Avatar
    Apr 2016
    Elmira, NY
    Hey all. Been a while since I have posted, but have recently felt the GP doesn’t have the “go” that it used to. It has 96k miles on the clock. The knocking noise or clicking noise isn’t the lifters I don’t think. It more or less sounds like clicking from a stretched timing chain. Is that possible at this mileage? What is the typical service interval for the timing chain?
    2003 Grand Prix SE, stock.
  2. #2 Re: Clicking/knocking under heavy acceleration
    I doubt it's timing chain related.
    The clicking/knocking is probably engine ping you are hearing. If the get up and go is no longer there, it could be struggling to get exhaust gases out of the engine.
    Or it could be a fuel related problem where it's pinging because it's lean.
    For test I'd grab a temp gun and see just how hot the cat converter is getting. If it's plugged up bad, it would start glowing when it's really dark outside.
  3. Likes tomsteve liked this post
  4. #3 Re: Clicking/knocking under heavy acceleration
    Apr 2016
    Elmira, NY
    I mean there never really was a whole lot of power to begin with, but it just feels less now than when I got it at 56k miles. I’ll check the cat, maybe move up a fuel grade to see if that solves the pinging. I’m sure it could use a fuel filter. I doubt it’s had it changed in its life.
  5. #4 Re: Clicking/knocking under heavy acceleration
    Apr 2014
    commerce twp,mi
    not sure about the 03 but my 08 has quite a bit of pep at 121000. enough pep to break the tires loose at a standing start if i want to. not roast the tires, but theyll squak.
    might want to pull some codes and see if ya have a misfire/non fire cylinder happening. how old are plugs,wires, and air filter? might need a throttle body cleaning,too.
    08 grand prix NA3800
  6. #5 Re: Clicking/knocking under heavy acceleration
    Apr 2016
    Elmira, NY
    I don’t have any check engine lights or any that have come up since I’ve owned it. I did a pretty thorough throttle body cleaning probably 6-8 months ago. Plug wires are OEM as are plugs. Filter (AEM brand) was just cleaned a month ago at oil change.
  1. Slow acceleration or no acceleration
    By tierzu in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-30-2015, 01:05 AM
  2. clicking/knocking 0-30mph
    By Senshi09 in forum Brakes/Suspension/Chassis
    Last Post: 11-16-2013, 05:05 PM
  3. rough under heavy acceleration
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-03-2012, 02:20 AM
  4. CAI now clicking?
    By Vioarr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2010, 11:05 AM
  5. weird missing on heavy acceleration
    By ricky861986 in forum Introductions/Noob Questions
    Last Post: 04-27-2009, 03:30 PM
