Thread: Temperature Control problem
Results 1 to 16 of 16
  1. #1 Temperature Control problem
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    I have a 2000 SE 3.1. The blower blows cold air n over heating . If I turn the hot/cold knob I can hear the blendor closing. When I turn the knob that directs the air and turn it to defrost the light in my a/c button comes on. Coolant level is fine.
  2. #2 Re: Temperature Control problem
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Your car is overheating? Bleed the cooling system. Maybe change your thermostat.
  3. #3 Re: Temperature Control problem
    GXP Level Member
    Mar 2015
    Tomball
    Nope not thermostat, he's low on coolant.
    Jeff
  4. #4 Re: Temperature Control problem
    Apr 2015
    Quote Originally Posted by J57ltr View Post
    Jeff
    He just said the level is fine....
  5. #5 Re: Temperature Control problem
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    my bets on a gunked up system, bad flow to the Heater Core
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  6. #6 Re: Temperature Control problem
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by CelibateHalibut View Post
    Is that the level in the overflow bottle where did he check it? Overheating and loss of heat are classic indicators of low coolant.
    Jeff
  7. #7 Re: Temperature Control problem
    Its a 3100. My guess is the head gaskets are blown. O2 gas filling the core
  8. #8 Re: Temperature Control problem
    GXP Level Member
    Mar 2015
    Tomball
    Sure wouldn't be the first time but they are famous for LIM gaskets as well.
  9. #9 Re: Temperature Control problem
    Apr 2015
    Go out and rent or buy a head gasket tester and check it.
    How many miles?
  10. #10 Re: Temperature Control problem
    How many miles?
    just what is a head gasket checker??????? come on now. lets try the proper terminology.
    you can rent a compression tester.
    or a o2 gas tester kit. art # for tester is in the vid.
  11. #11 Re: Temperature Control problem
    Sep 2013
    tulsa okla
    no overheating. Colant in radiator and overflow tank fine. Wondering why the a/c knob lite comes on when I turn it to defrost and air won't warm or change directions.
  12. #12 Re: Temperature Control problem
    flush your heater core. and look for a busted vac line off the back of the engine to the firewall then down the pass side fender under the fuse box. changing the battery can break the line, or it could be broken somewhere else. that vac line is what powers the airs direction of flow. def, vent, flow, or the mix of them.
  13. #13 Re: Temperature Control problem
    GXP Level Member
    Mar 2015
    Tomball
    The AC comes on because you have it selected to defrost. It's to dry the air.
    Jeff
  14. #14 Re: Temperature Control problem
    Apr 2015
    Scott, I just typed "head gasket tester" into Google and the first thing that showed up was the blue fluid thing. I don't see the problem.
  15. #15 Re: Temperature Control problem
    very vague info.......so i added to it. see how my post has more info lol
  16. #16 Re: Temperature Control problem
    Apr 2015
    Yeah, I was in a hurry to type something so I wasn't too in depth.
  1. Can you replace worn buttons on '06 temperature control/DIC?
    By nickbuol in forum General Tech Discussion
    Last Post: 07-13-2017, 08:16 AM
  2. Traction control problem
    By Grand prix 06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2015, 02:13 AM
  3. Temperature readings pre/post cat - normal or problem?
    By wmorrison65 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2015, 09:19 PM
  4. Temperature on climate control
    By traildog in forum General Tech Discussion
    Last Post: 02-02-2014, 08:56 PM
