Thread: clutch or?
Results 1 to 8 of 8
  1. #1 clutch or?
    Aug 2008
    Seattle, WA.
    Hey guys, when I am sitting at a light in my 89 2.3 liter quad four, 5 speed manual, car is warmed up, I go to shift to 1st and it grinds, I actually have the clutch peddle down to the floor from when I stopped and putting it in first I can feel the gear or something spinning and I got to pop it in to first with the grinding sound, clutch is only 6 months or so old. any idea's on what to check, or does it sound like I put in a cheap ass clutch?
    1997 Grand Prix SE 3800 series 2
    No mods yet.
  2. #2 Re: clutch or?
    Banned - Busted For Scamming
    Feb 2009
    Yea its not fully disengaging it sounds like. You might have air in the hydraulic system.
  3. #3 Re: clutch or?
    Aug 2008
    Seattle, WA.
    Can you walk me through the bleeding procedure, schucks is out of manual's,
    Thanks.
    No mods yet.
  4. #4 Re: clutch or?
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    ive never had to bleed a hydraulic clutch system. im a big rig mechanic. i believe its just like bleeding brakes. pump pump pump, open bleeder till fluid comes out, top off fluid, pump pump pump, open bleeder till fluid comes out, top off fluid...and so on
  5. #5 Re: clutch or?
    Aug 2008
    Seattle, WA.
    Ok when I replaced my clutch, I was hooking up the cable to the pedal and didn't remember if there was a e-clip on there or anything to hold the cable in place, well turns out there is som sort of clip on the pedal shaft that had broke, which cause my cable to tweek just enough to prevent clutch from fully disengaging, so put a sm. hose clamp on to keep cable on pedal and no more grinding.
    No mods yet.
  6. #6 Re: clutch or?
    Feb 2009
    Ok cool, yea i was getting at there might be a problem with the cable/ hydraulic system, didnt actually know which one that had. Thought most gms had the hydraulic. Glad to hear you got it worked out.
  7. #7 Re: clutch or?
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    hey grandprixnewb, what kind of 89 quad4 5 speed u have? i have been lucky enough to have owned an 89 cutlass calais international, 2.3 auto....never again but i sure miss it. it was a true cutty
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  8. #8 Re: clutch or?
    Aug 2008
    Seattle, WA.
    Quote Originally Posted by mikedinthecity View Post
    It's a 89 cutlass calais s. 4 door sedan with the five speed manual, love this car's power.
    No mods yet.
  1. 98 GTP A/C Clutch
    By maxster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2012, 05:52 AM
  2. ac clutch
    By gtbeach in forum General Tech Discussion
    Last Post: 03-06-2009, 11:59 PM
  3. 4th gear clutch hub install
    By CT Tech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-06-2008, 11:03 PM
