BUY HERE: Pontiac Grand Prix Control Arms - Front
Worn ball joints or loose rear bushings can cause excessive front tire wear, popping or creaking in the front end, extra play in the steering system, and pose a serious safety concern. Replace that heavily rusted, rotted, or damaged front upper control arm with the loose bushings or worn ball joints with our high quality all in one replacement.
One way to diagnose a loose, or warn ball joint on a control arm, is to jack the car up, so the wheel is off of the ground, then have someone try to move the wheel in and out. While they are moving the wheel check the ball joint and bushings for play, if it is moving you probably need to replace it.
