I have a 06 gp gt s/c and my traction control WILL NOT shut off that's right you push the button and nothing it sometimes needs to be off like in snow.Anyone else ever run into this and can this be fixed? Thanks for any feedback and help!
Have you had it scanned with a abs scanner.,
I will check the wiring and the abs light isn't on ig i could have it checked
Mine did this. I figured out there are three wires when you touch two of them together and let go it turns the t/c off and on. So I bought a pressure switch and wired the two wires to it so when you press the switch down and let it up it completes the circuit and turns it off and on. Mines an 04
Sent from my SM-S820L using Tapatalk
