Thread: 2000 GTP Differential swap questions
Results 1 to 4 of 4
  1. #1 2000 GTP Differential swap questions
    Dec 2013
    IOWA
    My dirt track car spit a passengers axle out, and messed up the splines inside that I can't get a new axle to go in, so looks like i'm going to have to replace the diff. I have never done this before and tried looking online for the step by step process to change it, but can't find anything, can anyone tell me what to expect or post a step by step instructions, I don't know **** when it comes to fwd cars. Also can I replace it from one from a gt around the same year, or does it have to be from a supercharge car? And is it just a swap in and go? Thanks in advance for any info.
  2. #2 Re: 2000 GTP Differential swap questions
    Needs to be from another GTP car, or one with the same gear ratio.
    The axles on the passenger side are different length for GT and GTP cars and the final drive raito is different, GT being 3.29 and GTP 2.93.
    I don't know exactly what to do for the swap, but I know it can be done in car.
  3. #3 Re: 2000 GTP Differential swap questions
    Jack passenger end higher than driver and or drain fluid. Me..I'd jack it up and deal with whatever came out when I pulled the diff cover.
    Pop the balljoint
    Pull the axle (Seems like you have this already done)
    Remove the trans to engine bracket (4 13mm bolts)
    Remove two more 13mm bolts holding the diff cover on
    Now you'll be looking at the diff. A medium to large screwdriver should get placed between the diff pin and the shaft that runs across to the other axle. Smack with a hammer and the shaft should push backwards and your diff is in your hands.
    If when you put things back together ... you can't hold the cover flush with just your hands, then you have to pull it again, right behind the diff is the parking gear, slide that out. Behind that is a bearing. If that parking gear slid forward..that bearing falls and makes things not fit. Use a dab of grease to hold the bearing to the parking gear and reassemble.
    Tip.. when putting it all back together have a buddy pull the driverside CV toward the tire for you to put it together, or if working alone, pop the drivers BJ as well and slide that axle out about 2 inches. Once you complete putting the diff together, then pop that back in and seat it into the diff.
  4. #4 Re: 2000 GTP Differential swap questions
    Dec 2013
    IOWA
    Thanks for the info guys, now which one of these is correct for my car, they are all listed as fitting 2000 GTP, I don't want to order the wrong one:
    http://www.ebay.com/itm/4T65E-34T-DI...da1aac&vxp=mtr
    http://www.ebay.com/itm/4T65E-38T-DI...9dd951&vxp=mtr
    http://www.ebay.com/itm/4T65E-42T-DI...daa534&vxp=mtr
    Here is the axle that oriles gave me:
    Outboard Joint Type: Spline Nut SKU: STK:GM-8097
    OB Spline Count: 33 Brand: SurTrack
    OB Nut Size (mm): 33 Manufacturer Part Number: GM-8097
    Number of Outboard Splines: 33 Number Of Inboard Splines: 39
    UPC: 00844084030979
    Measurement Type: Compressed
    Thread Pitch (mm): 2 Location: Front Passenger
    Overall Length (mm): 620 Length (mm): 620mm
  1. Couple questions about my 2000 GTP
    By LS1SSChris in forum General Grand Prix Discussion
    Last Post: 02-18-2015, 06:40 PM
  2. Questions regarding gen v swap
    By jayroca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-04-2013, 10:46 AM
  3. A Few Swap Questions
    By jaybaum96 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2012, 07:18 PM
  4. Top swap questions
    By killer84 in forum General Tech Discussion
    Last Post: 12-17-2010, 08:28 PM
  5. 2000 GTX questions?
    By basshead42 in forum Brakes/Suspension/Chassis
    Last Post: 04-19-2009, 01:47 AM
