Thread: Transmission Compatibility
Results 1 to 9 of 9
  1. #1 Transmission Compatibility
    May 2013
    Wheelwright
    I currently have a 2000 model Buick Regal GS with a 1998 model GS drive train. The trans is taking a dump after 3 years of being modded. I found a 2004 Monte Carlo SS trans with 27k miles for $200 with a guarantee and 30 day warranty. The numbers on the SS trans are 24220310. Would it work with my setup? Thanks in advance.
  2. #2 Re: Transmission Compatibility
    Mar 2014
    Tucson
    I don't think so. IIRC, 2003 is the last year that would work. (without internal modifications)
    What are the letters/numbers on the ID tag of the donor trans?
  3. #3 Re: Transmission Compatibility
    2003 is a funky year, for ease..replace 03's with only 03's
    04-08 is different enough that you can't easily put it into 97-02 cars.
    You'd be best to stick to a 98-02 trans.
  4. #4 Re: Transmission Compatibility
    May 2013
    Wheelwright
    24220310. Thats the numbers on the little white sticker on it.
  5. #5 Re: Transmission Compatibility
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    there should be a metal tag on he back.
  6. #6 Re: Transmission Compatibility
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    You can run an 03+ trans in your car if you replace your ECU with an 03 Regal GS ECU / Code.
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  7. #7 Re: Transmission Compatibility
    Oct 2012
    Pinckney, MI
    Here's my thread about the swap I did almost 10 years ago:
    http://www.clubgp.com/newforum/tm.as...de=&s=#3016907
    -Rob
  8. #8 Re: Transmission Compatibility
    Rob..does the bcm etc all play nice?
  9. #9 Re: Transmission Compatibility
    Oct 2012
    Pinckney, MI
    Bill,
    On my 99 Regal I had no issues. The BCM played nice, no issues with the passlock system as well. I drover that car for ~6 years with no problems, and sold it to a buddy that's still driving it.
    -Rob
  1. Transmission compatibility
    By SgtMarshal in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-21-2015, 08:01 PM
  2. Transmission compatibility
    By mintygp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-13-2013, 12:29 AM
  3. 2003+ Transmission in 2001 Grand Prix 3.8 NA compatibility
    By jj5428 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-24-2013, 01:07 PM
  4. transmission compatibility concern
    By synysterjoe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-12-2013, 11:49 AM
  5. Transmission shift solenoid compatibility
    By BackInBlack in forum General Tech Discussion
    Last Post: 10-18-2008, 01:19 PM
