Thread: Transmission cooler line flow
Results 1 to 9 of 9
  1. #1 Transmission cooler line flow
    May 2012
    Bloomington, IN
    I've been trying to determine what the correct flow in and out of the transmission is.
    There is conflicting information on here and online, not sure if I'm mixing up the info, but could just use clarification.
    I assume the top trans cooler line on the radiator is FROM the transmission and the bottom line is the RETURN to the transmission.
    If anybody can clarify or provide info I'd appreciate it, thanks.
  2. #2 Re: Transmission cooler line flow
    Mar 2014
    Tucson
    Transmission pushes fluid into the bottom of the cooler. Returns to the trans from the top.
    I can only assume it's done this way to purge air from the cooler.
  3. #3 Re: Transmission cooler line flow
    Page 77 I think has the flow for ya.
    http://www.grandprixforums.net/threa...ght=trans+info
  4. #4 Re: Transmission cooler line flow
  5. #5 Re: Transmission cooler line flow
    May 2012
    Bloomington, IN
    Wow fantastic info. Ok so here's what I did, I have the Hayes basic trans cooler set up AFTER the radiator, and I positioned it right in front of one of the twin air ducts/grille on the bumper. My concern is that will this cool off the trans fluid too much. Should I install a thermostat just to be safe. I live just south of Indianapolis so it does get pretty chilly down here in the winters.
    Please let me know thanks!
  6. #6 Re: Transmission cooler line flow
    GTP Level Member
    Aug 2012
    st louis park, MN
    I set mine up the same way as you and I live in Minnesota. I wouldn't be concerned about cooling the fluid too much although in the winter you don't need the extra cooling. You can always cover the transmission cooler in the winter to keep air from flowing through it.
    My assumption is a thermostat in the transmission fluid line would deprive the transmission of fluid. I wouldn't do that.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  7. #7 Re: Transmission cooler line flow
    If you are concerned, look into the LPD coolers. They bypass the cooler if the fluid is too cold.
  8. #8 Re: Transmission cooler line flow
    SE Level Member GEMINIokc's Avatar
    Dec 2008
    n side
    Just bought an LPD today Billboost Was searching the forums trying to figure out best way to install it. what lines go where etc. Any advice is Much appreciated
    UPDATED MODS....GreenBastard HP powertune, CAI, BlueGTP91 Engine bay detail, Finished painted Dash,Hogans Performance DP, Flow Master 40's, Still Missing driver side badge 4 weight reduction.... More Mods Coming Soon!!
  9. #9 Re: Transmission cooler line flow
    May 2012
    Bloomington, IN
    So I installed a Hayden 402 transmission cooler that was somewhat small and easy to place. The best thing you can do for yourself is get a Hayden 397 fitting. This fitting will allow you to install the cooler without cutting into any lines. I installed my cooler on the passenger side (PS) of the front. I took off the radiator fans and front bumper cover. I oriented the placement of the cooler in front of the PS vent in the bumper, at least close enough for air coming through the vent to catch a majority of the cooler. I un-plugged the upper radiator trans cooler line, I then installed the fitting into the trans cooler port on the end tank of the radiator so then you're left with two pipe ends which are perfect for the tubing in the kit. I then used the included zip ties to run them through the cooler, condenser, and radiator. Removing the fans just help situate these, you don't have to but it would help with a larger cooler. With this setup you then run the cooler after the radiator, as I learned above. Pretty easy to do.
  1. transmission cooler line to radiator size
    By KC04GTP in forum General Tech Discussion
    Last Post: 05-05-2015, 04:56 AM
  2. transmission cooler line part number?
    By andremike in forum General Tech Discussion
    Last Post: 11-17-2014, 08:31 PM
  3. "oil" on transmission cooler line
    By Coldwaves in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-07-2013, 12:34 PM
  4. Transmission cooler line
    By jhnnyboz in forum General Grand Prix Discussion
    Last Post: 08-24-2012, 08:03 AM
  5. Transmission Cooler Line leaking at radiator
    By Obrigado in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-01-2010, 04:36 PM
