Thread: Trans Upgrade what gear ratio?
Results 1 to 8 of 8
  1. #1 Trans Upgrade what gear ratio?
    Donating Users timboku's Avatar
    Montgomery, IL
    Gonna be pulling the trans out with the motor to upgrade it. I have a 300m input shaft on the way along with the hardened 4th gear. Going to be getting the single chain. I have a stock 65e HD. What gear size are people running are the 3.29 ratio that much better? On TEP website they say the 2.93s tend to be a little stronger? Any thoughts? Also, anything else I can do while its out? Not looking for a full all out build just some basic stuff while its out. Transgo shift kit going it as well. Thanks for any input!!
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  2. #2 Re: Trans Upgrade what gear ratio?
    GT Level Member Hardonyomom's Avatar
    aurora
    Bump
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  3. #3 Re: Trans Upgrade what gear ratio?
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    On an M90 car I like 3.29's over 2.93's. I don't exactly get why they'd be "stronger" but I can see them lasting longer.
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  4. #4 Re: Trans Upgrade what gear ratio?
    Montgomery, IL
    Quote Originally Posted by WhiteLightningGTP View Post
    Thats what was thinking as well. Just wanted to be sure but here is what the site says. Its at the bottom. It says they recommend the 2.93s over the 3.29s for higher hp builds but most people switch to the 3.29s ratio.
  5. #5 Re: Trans Upgrade what gear ratio?
    Dec 2012
    Where 4T65E's were born
    Well all the 4t65e-hd's came with 2.93 I believe. Not positive though. And think about it they don't change the ratio as much either, less output torque.
    Sold.
  6. #6 Re: Trans Upgrade what gear ratio?
    Nov 2012
    Frankenmuth, MI
    They had 2.93, 3.05, 3.06 and 3.29
  7. #7 Re: Trans Upgrade what gear ratio?
    Dec 2012
    You mean 4t65e's in general? I don't think 4t65E-HD came with all of those.
    Sold.
  8. #8 Re: Trans Upgrade what gear ratio?
    Nov 2012
    Frankenmuth, MI
    HD. Non HD'HD's had several other gear ratios as well.
  1. 01 trans in 04 GT throwing inccorect gear ratio code.
    By Wakeboy1337 in forum PCM Tuning
    Last Post: 05-30-2013, 01:38 PM
  2. gear ratio
    By shawnschuldt in forum PCM Tuning
    Last Post: 05-02-2011, 08:04 PM
  3. Gear ratio's??
    By reallyfast1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-10-2010, 10:10 AM
  4. Gear Ratio Pro's and Con's
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2009, 03:02 PM
  5. what is my differential ratio, and first gear ratio?
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-07-2008, 09:31 AM
