Thread: transmission cooler
Results 1 to 20 of 27
  1. #1 transmission cooler
    Sep 2014
    winchester
    Hi
    I have a 05 Pontiac Grand Prix with 200,000 miles and have changed the transmission fluid around 130,00 and its due for another one actually. The person before me probably never changed it at all. I had to change the radiator and put a new one couple of months ago and was curious if I bought a external transmission cooler like a TRU-Cool LPD or Haynes if I still used the transmission cooler that is in the radiator or should I bypass it?
    Thanks
  2. #2 Re: transmission cooler
    The Boss Iceman6669's Avatar
    Jun 2011
    Im pretty sure you bypass the one in the radiator if you get an after market one.
    2011 F-150 Yote powered
  3. #3 Re: transmission cooler
    Sep 2014
    winchester
    Also what size transmission cooler should I get? I live in Ohio but the price isn't a factor since I wont to keep my car until it falls apart.
  4. #4 Re: transmission cooler
    Aug 2013
    McDonald PA
    No you don't bypass the stock one. I have a Hayden 1405 run in series. Saw temps up to 195 and that's it during the summer in traffic and I see like 160 on the highway. Totally worth the 40 bucks I paid and the 12 dollars in hardware to install it
  5. #5 Re: transmission cooler
    Arizona
    Bypass
  6. #6 Re: transmission cooler
    Sep 2014
    winchester
    What extra hardware did you buy? Thanks
  7. #7 Re: transmission cooler
    Arizona
    Slice the rubber lines- double barbed 3/8ths fittings and fuel injection clamps. And llof course 3/8ths oil cooler hose
  8. #8 Re: transmission cooler
    GTP Level Member buickman104's Avatar
    NYC
    In my experience I would not bypass the radiator. I bypassed it at first because I had a small hose leak on the radiator side. I bought a Haynes trans cooler and ran it directly to the external cooler. During the summer I was fine. In the winter I noticed on my aeroforce that the temperature never went above 100-130 and it took forever to get to that temp. After that I got a piece of cardboard to partially block off the aux cooler in hopes that my trans would run at operating temp. It was somewhat sucessful at getting the trans to the 160-175 degree range but still took forever to get there. Last winter in city driving conditions I was at a light my trans temp was still at 80 degrees and as I pulled away from a light I had slip in 1st gear. I noticed this happened only when the trans was too cold.
    This month I plan on buying new lines and running them through my radiator to my auxiliary then back to my trans. That way my fuild will have no problems getting up to temp.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  9. #9 Re: transmission cooler
    Arizona
    Was this Dex 3 you were using ? Newer gp's use the dex6 which is synthetic. Which would be diffrent.
    I've never had a issue even when its sub 10 degree weather.
  10. #10 Re: transmission cooler
    Oct 2011
    Toledo, OH
    Quote Originally Posted by 91parkave View Post
    FYI, 05 (what OP has) came with Dex 3. 06+ Came with Dex 6.
    I vote run in series because GM cars that came with an auxiliary external cooler like the Impala police car have them ran in series with the radiator.
    Also, Welcome fellow Ohioan, there is quite a few of us here.
    7"
  11. #11 Re: transmission cooler
    Arizona
    Quote Originally Posted by industrialfish View Post
    Doesn't matter the year you can convert to Dex 6.
    Regardless you can run how you want. My logic is simple- I'd rather keep the absolutely inefficient factory brick cooler out the transmission loop. I have yet to see a case where the trans suffered from running colder as compared otherwise
  12. #12 Re: transmission cooler
    NYC
    I have a rebuilt trans running pure and clean dex 6.
  13. #13 transmission cooler
    Aug 2013
    McDonald PA
    Hmmm maybe I'll go to standalone
    I'll see how winter goes with my torque converter lock
  14. #14 Re: transmission cooler
    NYC
    And i've had an issue so we are 1:1
    I doubt Arizona sees as much cold ice and snow as the North East.
  15. #15 Re: transmission cooler
    Jul 2013
    Richmond, VA
    I put a 404 (I think) in last year in series with the radiator cooling. Check out the pics HERE.
  16. #16 Re: transmission cooler
    Sep 2014
    winchester
    Has anyone installed this transmission pan on their Grand Prix?
    http://www.ebay.com/itm/LOW-PROFILE-...-/111197690062
  17. #17 Re: transmission cooler
    Oct 2011
    Toledo, OH
    Quote Originally Posted by bryanrhoads77 View Post
    You can get a similar one made by Dorman for about $35
    7"
  18. #18 Re: transmission cooler
    Aug 2013
    McDonald PA
    I think I'll get one next pan drop
  19. #19 Re: transmission cooler
    GTP Level Member
    Aug 2012
    st louis park, MN
    You do an "in-series" where you include the radiator in the system. In this setup, I like to think of the trans fluid temp chasing your engine temp with some additional cooling provided by the auxillary cooler. All in all you'll likely see your trans fluid temp about 15-30 deg cooler. One upside, for those of us in cooler climates, is your radiator will help warm your trans fluid and bring it up to normal operating temps quicker during winter. This is the setup I have in my 2008.
    Or you can do a "standalone" where the radiator is not included in the transmission fluid cooling. This will likely provide better cooling in the summer since your trans fluid will not be running through your hot radiator. However, you will not benefit from the hot radiator in the winter and you may find you trans fluid temps staying very low. Also, I don't know how to appropriately size a standalone setup to prevent and overheating situation.
    If you'd like more information, you should be able to search out some threads. I know I've had a couple that got into some very detailed discussion. Let me/us know if you have further questions!
  20. #20 Re: transmission cooler
    Arizona
    Quote Originally Posted by buickman104 View Post
    I've been standalone for years when I was stationed in Colorado I had no issues. Your 1st gear slip could be attributed to much more than temps.
  1. Transmission Cooler
    By nukkinfuttz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-14-2012, 07:33 PM
  2. Transmission cooler line
    By jhnnyboz in forum General Grand Prix Discussion
    Last Post: 08-24-2012, 08:03 AM
  3. transmission oil cooler
    By 03buickregalls in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-01-2010, 09:11 PM
  4. Auxillary transmission cooler?
    By keenan00gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-21-2008, 06:35 PM
