Hey all,
Just something I'm trying as a learning experiment. I pulled a factory transmission cooler from a 2004 9C1 Impala (Police Cruiser). Today I decided to put it on my Grand Prix. Install was actually pretty easy. Figure I can drive around this labor day weekend and see what results I get.
Today (before cooler install) went on business trip, transmission temp (viewed with HP Tuners) was 220 peak, 210 average. (About 88* outside air temperature)
From what I've read, this is a perfectly healthy and normal temperature for this transmission. However, I have noticed that as the fluid temp becomes warmer, the PCS / TCC tend to act up more often (oscillating RPM's, hard shifts, P1811 code).... which is pretty normal behavior for a factory 4T65E with 276,000 miles, I would think.
At one time, I had tried putting a 180* thermostat in just for kicks and set fan settings to maintain 185* and watched trans temps. The temps stayed around 190-200* ... so, as one could reasonably expect, with only the radiator to cool, the trans fluid stays pretty close to engine coolant temps. At least that's been my experience. Transmission also seemed to behave better as well.
Not expecting any miracles from my old, tired transmission... just seeing what happens with a little extra cooling.
