Thread: 2004 GTP transmission vs GTP Comp G transmission
Results 1 to 10 of 10
  1. #1 2004 GTP transmission vs GTP Comp G transmission
    Donating Users Jordan's Avatar
    Oct 2011
    Richland Center, WI
    Is there a difference in the actual transmissions between a car with the paddle shift and those without? My Comp G needs a new engine and I found one nearby that includes a transmission, but I'm not sure if it was a Comp G or not, and if the transmission will work with the paddles if it didn't come out of a comp g.
    2009 Cobalt SS/TC Coupe |
    Summit White | 131k | ZZP charge pipes, ZZP heat exchanger, ZZP 3" downpipe, HP tuned, Muffler delete, K&N Typhoon intake, dual interceptors, retrofits with switchback halos
    2006 Grand Prix GXP | Black | 95k
  2. #2 Re: 2004 GTP transmission vs GTP Comp G transmission
    Omaha, NE
    There is a difference in the valve bodies. If you have a Comp G you need a Comp G transmission.
    The GXP trans has the same trans as the comp G with different gears.
  3. #3 Re: 2004 GTP transmission vs GTP Comp G transmission
    Dec 2012
    troll land
    What is the gears of a gxp? Just curious
  4. #4 Re: 2004 GTP transmission vs GTP Comp G transmission
    GXP IIRC is 2.93 while the Comp G is 3.29
  5. #5 Re: 2004 GTP transmission vs GTP Comp G transmission
    Dec 2012
    troll land
    So the same as a regular l67 setup then
  6. #6 Re: 2004 GTP transmission vs GTP Comp G transmission
    Dec 2012
    troll land
    Thanks btw
  7. #7 Re: 2004 GTP transmission vs GTP Comp G transmission
    beefier parts
  8. #8 Re: 2004 GTP transmission vs GTP Comp G transmission
    GXP has a completely different tranny case aswell, so you could never use it anyway.
  9. #9 Re: 2004 GTP transmission vs GTP Comp G transmission
    No, but you can flop most of the parts into your own trans case. Then use your channel plate and VB along iwth your wiring and it would work. Cause, I'm Bill and I've done it.
  10. #10 Re: 2004 GTP transmission vs GTP Comp G transmission
    Hahahaha.. local says he can't get a trans gasket anywhere. I make one call. It'll be at the store 1/2 mile from the house (and car) by 2:30-3pm
  1. 2004 gtp comp g transmission overheating
    By daltman360 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-12-2013, 11:26 PM
  2. 2004 Comp G transmission Filter.
    By Iceman83 in forum General Grand Prix Discussion
    Last Post: 02-24-2013, 07:48 PM
  3. 2004 Grand Prix Comp G transmission issues...
    By balt1024 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2012, 07:49 AM
  4. 2004 GTP COMP G warm weather transmission problem?
    By Kodiak19 in forum General Tech Discussion
    Last Post: 07-26-2011, 02:11 PM
  5. comp g transmission
    By 97grandprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-23-2011, 03:53 PM
