Bought a transmission from a 98 Buick Regal GS and am going to put it in my 01 GT. I already read up on the issues with the fittings for the tranny lines needing to be switched. Not a big deal. My bigger concern was that the casting on the tranny's bellhousing from the Regal says 910 and the one on my GT says 901 and then the one in My GTP says 911. I just want to make sure everything will bolt up before I tear into my GT.
Other questions I also had...
Is the 4th shaft hardened in the HD tranny before 03?
Anything I should replace besides the axle seals and input shaft seal before putting it in?
Will the regal torque converter work in the GT?
