Thread: Trans Cooler Line Help
Results 1 to 20 of 35
  1. #1 Trans Cooler Line Help
    May 2013
    Carthage
    On a 2000 Pontiac Grand Prix 3.8l, can anyone tell me which trans cooler line (top and bottom) is the inlet and outlet on the stock trans cooler on the radiator?
  2. #2 Re: Trans Cooler Line Help
    top line should be the pump line, pumps it into the top, flows out the bottom.
  3. #3 Re: Trans Cooler Line Help
    Dec 2012
    Where 4T65E's were born
    Are you sure? ^
    I know for sure the line that's facing the rear of the car on the transmission is the return line, I don't know 100% what the flow direction is on the cooler, but I thought it was the other way around.
    The line seen here is the one that flows back into the transmission:
    You can follow it up and know for sure.
    Sold.
  4. #4 Re: Trans Cooler Line Help
    you could always take both lines off and clicj the starter, only one will push fluid out.
    i did a tranny flush with my brother in his yukon the top line was the pump line, we put a clear tube to a pail from that line and pumped the old fluid out.
    makes sense hot in the top, cooler out the bottom. just like a rad.
  5. #5 Re: Trans Cooler Line Help
    Dec 2012
    Yeah radiators are like that so the air gets trapped in the rad, then as the car cools it sucks fluid in to fill it from the overflow. I thought since transmission reservoir are in the pan they want the air to end up there and not get stuck in the cooler. Idk, like scotty said you'll know when you take the line off and momentarily turn it over.
    Sold.
  6. #6 Re: Trans Cooler Line Help
    theres a few how to's dirtdog did one didnt he?
  7. #7 Re: Trans Cooler Line Help
    Dec 2012
    Yeah he did an imperial trans cooler install on his GXP, I'd assume it's the same. I was gonna make a write-up for us basic people with hayden tube and fin styles but I never committed to it.
    Sold.
  8. #8 Re: Trans Cooler Line Help
    he noted what lines pumped iirc
    same tranny. so.......
  9. #9 Re: Trans Cooler Line Help
    Arizona
    bottom of factory trans coolers are usually on the bottom and return line is on top. Personally i think thats stupid and prefer to work with gravity so i reverse that.
  10. #10 Re: Trans Cooler Line Help
    Dec 2012
    I don't think gravity has a different effect one way or the other because it goes up just as high either way. Would be a good thing to test though.
    Sold.
  11. #11 Re: Trans Cooler Line Help
    May 2013
    Carthage
    Thanks guys for responding, what I'll do is just follow up the transmission line that runs straight into the pan area, which would be the cold return line, I'll follow that up and see if it connects to the upper or lower connection on the factory radiator, and that will be the line I hook to the external trans cooler...
    Another question with installing the external trans cooler...I will be mounting it horizontally in front of the ac condenser and just wondering if the top or bottom connection of the external trans cooler should be attached to the factory return line?? Will it make a difference either way?
  12. #12 Re: Trans Cooler Line Help
    GTP Level Member
    Aug 2012
    st louis park, MN
    This may provide some additional guidance for your installation.
    http://www.grandprix.net/upgrades/cooler.html
    I don't quite understand your second question but it doesn't matter how the cooler is oriented. Take a look at this instruction manual - their diagrams may help simplify things.
    http://www.haydenauto.com/Upload/Hay...il-coolers.pdf
  13. #13 Re: Trans Cooler Line Help
    May 2013
    Carthage
    Hey guys, just so everyone knows the transmission line that runs straight into the transmission pan (like the picture posted at the top of this forum) runs into the top of the radiator. This means the fluid supply line runs to the bottom of the radiator and flows back to the transmission from the top of the radiator...bottom of rad=inlet and top of radiator = outlet
    Could not install the shift kit or trans cooler since the supply line running to the bottom of radiator was leaking and no parts store has in stock around my area.....I imagine the stock supply line couldn't handle the max line pressure created by the p1811 max adap trans code...
    I will keep everyone posted on the install of both shift kit and cooler when I'm done..
  14. #14 Re: Trans Cooler Line Help
    Dec 2012
    Cooler lines can take lots of pressure, but not while rusted. Sometimes the crimp where it turns into a rubber hose leaks but that's a bad design. New lines are not always carried at parts stores but are on rockauto for a pretty good price.
    Sold.
  15. #15 Re: Trans Cooler Line Help
    GTP Level Member
    Aug 2012
    st louis park, MN
    Robriley, after getting home from work today I checked where my cooler was tapped in, low and behold I was wrong! The return line comes from the top of the radiator, as you've stated, and that is where your cooler should be spliced in. Sorry to mislead you; best of luck moving forward!
  16. #16 Re: Trans Cooler Line Help
    May 2013
    Carthage
    That's ok, I'll be doing both the cooler and shift kit today so hopefully all goes well....I also decided to purchase fuel injection hose clamps instead of the standard worm clamps. I will let everyone know how it goes!
  17. #17 Re: Trans Cooler Line Help
    May 2012
    Bloomington, IN
    Sorry, I've done a lot of reading so the top line is for sure the return, even on an '04 GP N/A I'll assume it is, then splice in at the top run to the cooler, just want to make sure, thanks.
  18. #18 Re: Trans Cooler Line Help
    May 2013
    Carthage
    Just so everyone knows the shift kit installation went pretty smooth, I took my time and cleaned everything up, swapped the springs according to the Transgo shift kit instructions, and a few hours later i had the pan bolted back up ready to go. I then had to replace the supply line to the bottom of the radiator since it started seeping as a result of the P1811 max line pressure command...After struggling using a 3/8" transmission line disconnect tool and spending about a half hour too long not being successful with this disconnect tool, I used a tiny flathead and hammer and popped the clips out in a few mins. After about 5 hours total of installing the shift kit, the supply line, and running back and forth to the parts store...I decided to hold off installing the transmission cooler for the time being.
    I had removed the plastic grill pieces that run along the hood latch area, both the headlights, taking measurements, trying to figure out where to route the transmission cooler lines....it was just too much of a project to tackle for the day. I'd like to hear from others that have installed the transmission coolers on Grand Prix's, how you guys routed the transmission cooler lines? My transmission cooler lines said not to have less than a 3" bend when routing the lines, one of the few possibilities of routing the trans lines was a small hole behind the passenger side head light...the battery sat right there past the hole along with the top radiator fitting pretty close....on top of all this there was a vertical bar running from the top of the hood latch assembly down to the bottom of the ac condenser which prevented me from mounting the Imperial High Performance Trans Cooler without modifying this vertical bar....
    Like I said before I live in upstate NY which gets pretty cold in the winter, anyone that has installed a transmission cooler in these Grand Prix's, let me know how you guys routed the cooler lines..
    Thanks!
  19. #19 Re: Trans Cooler Line Help
    GTP Level Member
    Aug 2012
    st louis park, MN
    Quote Originally Posted by robrileyw View Post
    Thanks!
    Rob,
    I installed an in-series cooler last fall and will describe my approach. I also spent way more time planning/measuring than it actually took to install the cooler. I mounted my cooler on the driver's side of the car and routed the lines around the driver's side of the ac condenser/radiator (I use these terms interchangeably which is probably wrong).
    First, here is a sketch I made of my setup on a 2008 base 3.8L. The perspective is drawn from the front if you were standing slightly towards the drivers side:
    EDIT: THE LINES SHOWN ABOVE ARE INCORRECT - THE ENDS ARE LABELED CORRECTLY BUT HOW THEY CONNECT TO THE RADIATOR ARE FLIP FLOPPED. THE TOP LINE FROM THE STOCK RADIATOR IS THE RETURN LINE AND SHOULD BE TAPPED INTO.
    If I remember correctly, the transmission lines connecting were metal on the ends connecting to the transmission and radiator with a segment in the middle that was the same rubber tubing as was provided in my cooler kit. This is where I tapped in. I located my cooler as directly behind the drivers side grill opening as I could. I figured this would provide the most airflow vs behind the bumper or other obstruction. I think I took a different approach to routing my lines than others but it was very clean and has worked great so far. I was able to route my lines immediately outside of the AC condenser/radiator. There was a plastic guard or brace (might be the "vertical brace" you were referring to) just outside the radiator but I was able to route my lines BETWEEN the two without kinking or breaking the 3" bend rule. Note that I actually DID route the lines high to low as they wrapped around the radiator, this softened the curve in the lines. If I were to wrap them around the condenser on a level plane I think the bends would have been too sharp. If your car has the same setup as the 2008 model you should see this once you start digging in. My lines came out at the same location where the rubber portion of the original transmission lines were located so it was easy to tap into once I got them routed through the gap.
    I had to take of the big plastic bottom guard which was somewhat challenging at times. Other than that I don't think I disassembled anything else.
    Let me know if you'd like more information or want pictures of my setup.
  20. #20 Re: Trans Cooler Line Help
    May 2013
    Carthage
    Thanks alot Stocker! You just inspired me to go through with the trans cooler job! But first just a few questions....which trans cooler did you install? Do you remember the size of the rubber lines you got the copper connections for (I'm thinking 3/8 rubber line) ??
    Anyways I will take off my front bumper, the bottom plastic panel, mount the trans cooler towards the driver side towards the top like you...the only difference between your 2008 and my 2000 grand prix is the supply line runs to the bottom of the radiator and return line runs from the top...Did you use the standard worm clamps with the copper connections?
    Thanks a bunch for the detailed write up along with the illustration, I really appreciate it!
  1. 2003 Grand Prix Trans Cooler Line Replacement
    By zmaddox5306 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-02-2013, 12:19 PM
  2. trans cooler line for my 2002 grand prix se 3.1 ?
    By philr roy in forum General Tech Discussion
    Last Post: 01-23-2013, 12:19 AM
  3. Need help on cooler line issue - upgrading to a GTP trans
    By harner in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-04-2012, 04:04 PM
  4. Trans Cooler Line Leaking
    By johng80 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2011, 12:05 PM
  5. trans cooler line leaking
    By _nick_ in forum General Tech Discussion
    Last Post: 09-21-2011, 09:58 AM
