Hello all!
You probably can see that I'm new here, so, ya know...hi and stuff. Seriously though...I have been observing for a little while, and I have to say that this is a great forum with nice, helpful, non-ego people. How nice! I need your advice.
I'll start off with a little background. I don't have a 3800 or a w-body, sorry. However, I do have a 98 4T65E out of a Buick LeSabre that has the Intense Racing 3.69 single chain/gear conversion, and EP LSD. Otherwise, it's all stock with about 40K miles. With some help, I swapped that baby in my 94 Cavalier Z24. The car ,for now, retains the mostly stock 3.1 MPFI with bolt ons. For numbers, HP is ~165, and TQ ~205. That is a first for a Z24 and second for a j-body. I have the fully programmable CompCams transmission controller taking care of ALL, and then some, parameters of the tranny. Long story short: went racing, started leaking ATF, got home, found the side cover cracked at the bottom where a bolt would go. I have the cover, pump, valve body, and channel plate all off. I figured since I was there, I might as well check into the condition of things. So far, I have found 4th clutch steels have hot spots, and the clutches seem to be wearing more on the outside edges. The pump shaft (converter side) has a bit of wear on the splines. That concerns me with the low miles. I'm replacing the channel plate and accumulator gaskets, along with the valve body separator plate. My list of parts is as follows:
OD clutch kit, valve body sep plate, channel plate gaskets, and pump shaft.
I can get a used pump shaft on ebay for ~$15. Maybe the chrome moly on zzperformance for $130? The boost valve was replaced 6K miles ago, and I have seen all the other valves that are recommended for replacement. Which ones should I do if any?
I'm also looking to increase the shift speed, more so for faster downshifts. All the shift kits work on the 1-2 and 2-3, but not on the 3-4. Why? Why not shim the 3-4, even some? Is that bad to do, or simply not practical for the work involved? I was also wondering about the valving in the valve body. Dare I drill slightly larger holes to improve oil flow and speed up shifts?
I'll post a few pix soon as well.
Thanks for your input. It's very much appreciated!
Andy
