Thread: 4T65e with HD upgrade noise?
Results 1 to 3 of 3
  1. #1 4T65e with HD upgrade noise?
    Oct 2012
    Rochester, MN
    So i replaced the trans in my 2000 GTP with a 2000 GT trans with 120k miles. (stock on gave up after 220kmiles can you believe it?!)
    Ever since the swap my car has made a howling/humming noise. As the title says, i switched the HD diff into the GT trans.
    Any help would be great!!!!!
  2. #2 Re: 4T65e with HD upgrade noise?
    Check out TEP's website. Look at stator bearing. Often when the bearing gets worn, you get the noises you mention.
  3. #3 Re: 4T65e with HD upgrade noise?
    Oct 2012
    Rochester, MN
    Thanks! i appreciate it!
    i know my wheel bearing plays in half the noise.
  1. Swap out series 4T65E for 4T65E-HD?
    By CyxRyan in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-17-2013, 01:01 AM
  2. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  3. Tranny Swap 4T65E-HD to 4t65E
    By windowrattler in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2012, 03:47 PM
  4. HD swap/upgrade for the 4T65e nonHD trans
    By ninnyGTP in forum How To Write-Ups/Tech Tips
    Last Post: 06-13-2011, 10:48 PM
  5. 4t65E replacing 4t65e-hd question
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2010, 10:33 PM
